Unlimited caching on Linux results in long simulations hitting swap |
Chris Coutinho
Rep Power: 11 ![]() |
I am currently running some simulations as part of a parameter sweep on a modest Linux workstation (20-core, 128GB RAM, OpenFOAM 4.x on OpenSUSE Linux 42.2 Leap). I should probably also note that I'm running these simulations through PyFoam, maybe that makes a difference. I've noticed that as one of my simulation progresses, cached memory seems to keep going up. I've checked the cached memory usage on my machine using Code:
fincore I used to set the 'purgeWrite' option to 0 and just hold on to everything, but even when I set that to something like 5, it still keeps growing. At the time time of writing, I have about 4 GB of cache - most of which isn't needed. But this isn't ideal. There are cases when I want all of the resulting output data, but only on disk. When I didn't use the purgeWrite option, a simulation using a anywhere between 5-10 GB ended up using 60-80GB of cached memory before I cleared it using the following command: Code:
sudo sh -c 'echo 3 > /proc/sys/vm/drop_caches' Has anyone else dealt with this before? And if so, what is the proper way of dealing with this? Code:
filename size total_pages min_cached page cached_pages cached_size cached_perc -------- ---- ----------- --------------- ------------ ----------- ----------- ./0.org/C 1,773 1 0 1 4,096 100.00 ./0.org/p 1,380 1 0 1 4,096 100.00 ./constant/polyMesh/.gitignore 14 1 0 1 4,096 100.00 ./constant/polyMesh/points 153,447,808 37,463 0 37,463 153,448,448 100.00 ./constant/polyMesh/neighbour 68,336,322 16,684 0 16,684 68,337,664 100.00 ./constant/polyMesh/faces 306,676,372 74,873 0 74,873 306,679,808 100.00 ./constant/polyMesh/owner 69,687,860 17,014 0 17,014 69,689,344 100.00 ./constant/polyMesh/boundary 2,641 1 0 1 4,096 100.00 . . . . ./PyFoamHistory 235 1 0 1 4,096 100.00 ./PyFoamServer.info 25 1 0 1 4,096 100.00 ./PyFoamRunner.simpleSaltPeriodicFoam.analyzed/pickledStartData 476 1 0 1 4,096 100.00 ./PyFoamRunner.simpleSaltPeriodicFoam.analyzed/pickledPlots 210,270 52 0 52 212,992 100.00 ./PyFoamRunner.simpleSaltPeriodicFoam.analyzed/pickledUnfinishedData 1,561 1 0 1 4,096 100.00 ./PyFoamState.LogDir 47 1 0 1 4,096 100.00 ./PyFoamRunner.simpleSaltPeriodicFoam.logfile 1,044,300 255 0 255 1,044,480 100.00 ./PyFoamState.StartedAt 25 1 0 1 4,096 100.00 ./PyFoamState.TheState 8 1 0 1 4,096 100.00 ./PyFoamState.LastOutputSeen 25 1 0 1 4,096 100.00 ./PyFoamState.CurrentTime 6 1 0 1 4,096 100.00 ./postProcessing/lowerWallRegion/0/surfaceRegion.dat 18,351 5 0 5 20,480 100.00 ./postProcessing/upperWallRegion/0/surfaceRegion.dat 18,351 5 0 5 20,480 100.00 ./postProcessing/profileRegion/0/surfaceRegion.dat 18,349 5 0 5 20,480 100.00 ./PyFoamRunner.simpleSaltPeriodicFoam.logfile.analyzed/pickledPlots 138,980 34 0 34 139,264 100.00 --- total cached size: 4,438,556,672 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: Log File too Large
---- Edit: Sorry, I read your post too fast and mixed up information while I was moving several threads about PyFoam. I've had this issue in the past, namely that the cache would not flush automatically and it would end up going into the Linux swap. The problem is that I never figured out what exactly got broken and that resulted in this. The fix that has always worked was to simply do a cold reboot of the machine in question (safely/normally shut it down and turn it back on after a minute or so). After that, I was never able to reproduce the same error for isolating the problem. My guess is that there was some bad memory access by some library or application, which resulted in the cache management system to go nuts and do this. On the other hand, whenever it does not reach swap, then caching files should not hurt anything, since it's only caching for possible future re-reading of the read and/or written files. Technically, the files should be safely written to disk.
cache, linux, pyfoam |
SU2 Transonic Flow simulations bad results | S.Kontogiannis | SU2 | 12 | June 20, 2019 07:46 |
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 20:49 |
Unphysical Results of Low-Re Airfoil Simulations | ericthefatguy | SU2 | 2 | February 2, 2015 05:07 |
SU2 Transonic Flow simulations bad results | S.Kontogiannis | Main CFD Forum | 8 | May 16, 2014 12:22 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
