Pressure fluctuation
Old   November 27, 2017, 15:07
Question Pressure fluctuation
Mohamed Elghorab
crazzy.pirate43 is on a distinguished road
Dear Foamer,
I'm very happy to be a member of OpenFoam world. Nowadays, I'm trying to generate homogeneous turbulence at the inlet of channel flow which has fully developed UMean at inlet and a convection boundary layer for the pressure at the exit. The problem is that every run I get a problem with the pressure, it fluctuates from (+ve) to (-ve) between following time steps and therefore PMean is very small which means that in some time steps the pressure goes from low pressure at the inlet to high pressure at the outlet.
I attached 2 photos for the pressure behavior which affects on the behavior of the generated velocity fluctuation.
So could you please anyone can help me in this problem to know what may be the source of the error?
Thanks in advance for any help
Mohamed
The attached photos for the pressure:
1- for (-ve) pressure values after 8 cycles.
2-for (+ve) pressure after 10 cycles.
(one cycle refers to that a particle of the flow completed the distance from the inlet to the exit)
crazzy.pirate43 is offline   Reply With Quote
pressure fluctuations
Outlet pressure aja1345 FLUENT 5 August 18, 2015 12:02
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 22:33
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
