Unsteady flow with icoFoam
Old   November 24, 2017, 08:42
Default Unsteady flow with icoFoam
Mehrdad Sadeghi
Mehrdad.sadeghi is on a distinguished road
Hello every one, I want to simulate unsteady flow movement in a packed bed tube with a porous structure inside with different inlet velocities. I used uniformFixedValue for determining different inlet velocities during time. Since the mesh is too fine, I defined deltaT in boundary controlDict to 0.005to control courant number. After some iterations (5 or 6) the courant number increased sharply to a large amount, I received an error an simulation stopped. Do you have any idea what can be a reason for increasing courant number and stopping simulation?
Mehrdad.sadeghi is offline   Reply With Quote
Old   November 24, 2017, 08:46
BlnPhoenix is on a distinguished road
With the information given its just guessing what could be the error..
Try a lower timestep maybe.
BlnPhoenix is offline   Reply With Quote
Old   November 27, 2017, 08:21
Robert
RobertHB is on a distinguished road
Indeed, without further information it ist difficult to determine the cause of your problem.
A few ideas:
-Does your flow become turbulent? icoFoam is a laminar solver.
-Bad cells in your mesh?
-Timestep too large.
RobertHB is offline   Reply With Quote
Old   November 28, 2017, 10:30
Mehrdad Sadeghi
A few ideas:
Dear Robert
Thank you so much for your prompt reply and sorry for replying late.
The range of flow is in laminar regime (Reynolds number<100)
I used the same meshing for performing steady state simulation with simpleFoam. The simulation was converged and validated with experimental data and correlations.
Time steps is small enough because I checked the size of smallest cell and calculated courant number was OK.
Old   November 28, 2017, 11:01
Originally Posted by Mehrdad.sadeghi View Post
Dear Robert
You have high non-orthogonal cells, this is not ideal. Since solver blowup can be triggered by only one bad cell, i would try to re-mesh and get the max non orthogonality below 45.
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
When can we decide a flow is unsteady or periodic? and How? vidyadhar OpenFOAM Running, Solving & CFD 3 April 27, 2017 05:02
Unsteady interna flow yhoarau OpenFOAM Running, Solving & CFD 2 June 5, 2012 11:42
how to predict unsteady flow from case definition? Felix Main CFD Forum 6 August 28, 2007 17:40
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
