Abruptly varying outflow from two model outflow sections
Old   November 22, 2017, 14:47
Default Abruptly varying outflow from two model outflow sections
Sajjad Haider
s_haider is on a distinguished road
I am running a free surface flow model using interFoam. The bed slope is steep and flow is about 5 to 2 cm deep with Froude No. 2 to 4. The outflow from the two model outlets is verified by (postProcess -func flowRatePatch) which shows that it varies suddenly i.e in one second Q increases by 4 times. This is not normal. The outflow bc are zeroGradient and i am using 'cAlpha' equal to 0.5 as with default 1, the simulation crashed. How can I remedy this situation? Should I let simulation run for a longer period but the computational time is too long. Should I use LTSinterFoam given that the inflows at two inlets are both steady ?
As regards alpha water field, the calculated results are reasonable.
s_haider is offline   Reply With Quote
interfoam
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
coalChemistryFoam: "Foam::error::printStack(Foam::Ostream&) at ??:?" musabai OpenFOAM Running, Solving & CFD 2 February 20, 2015 15:07
Transient Model, Varying Mesh files... Erich CFX 7 September 11, 2007 11:15
How to model varying food models in a Blender Raymond CFX 0 July 10, 2004 00:40
Dimension of model and domain for outflow Leron Main CFD Forum 1 October 31, 2000 03:09
