perturbU links are dead
Old   November 20, 2017, 10:42
Default perturbU links are dead
rik houthuys
Houthuys is on a distinguished road
Dear all,
I need to download perturbU utility for OpenFOAM 4. I've followed the instruction here http://openfoamwiki.net/index.php/Contrib/perturbU.
Unfortunately the repository seems to be empty
So can anyone provide link for perturbU for OpenFOAM 4
Best regards.
Houthuys is offline   Reply With Quote
Old   November 20, 2017, 11:18
Rubens Stuginski Jr
rubens is on a distinguished road
The link is OK.
Try again.
rubens is offline   Reply With Quote
Old   November 28, 2017, 18:07
rik houthuys
Originally Posted by rubens View Post
The link is OK.
Try again.
Are you sure?
the links in the wiki article returns "404: Not Found"
wget https://github.com/wyldckat/perturbU/archive/OF40x.zip -O perturbU.zip
If you can access this file please share it here!
Old   November 28, 2017, 21:21
Rubens Stuginski Jr
Hi Houthuys.
I think this utilities is no more available. You can get more information in https://github.com/wyldckat/perturbU
Maybe Bruno (wyldckat) has more information about this utilities.
Sorry.
Rubens
Old   November 30, 2017, 06:16
Hilbert
Hillie is on a distinguished road
Hi Houthuys.
I assume you want to do some LES and need a perturbed field?
For my own LES i ended up making some small modifications to boxturb. boxturb gives you a uniform turbulence field, but changing the code to accept a baseline velocity is quite simple.
Hope it helps,
Cheers,
Hillie is offline   Reply With Quote
dead volumes in stirred tanks soroosh dbi FLUENT 0 July 11, 2017 12:35
Sharing links for two phase solver packages developed by openfoam community swap_9068 OpenFOAM Programming & Development 1 April 2, 2017 06:43
is PerturbU there in OpenFOAM 2.1? turbfoam OpenFOAM Running, Solving & CFD 3 December 26, 2012 16:18
Links Section - Major Update! pete Site News & Announcements 0 February 6, 2012 08:51
Dead cells created on edges when a grid file is generated in GAMBIT and imported into FLUENT4 Isaac Manohar Ch. FLUENT 1 June 2, 2000 05:58
