November 20, 2017, 06:34 |
Pipeflow with axial moving fibre.
Markus Häfner
Hi guys,
(Im new to CFD and new to OpenFoam) I am currently trying to model a pipe flow with a fibre inside a pipe with an axial velocity u_F. To give you a better understanding of this case you can have a look on the enclosed pic. I started with the pitzDaily example for incompressible fluids and the simpleFoam solver. I thought I can model the moving fibre defining a boundary condition on that wall with the fibre velocity. I noted that with this definition I created a new mass or volume flow into the system. What of course is not what I want. So my question: Does someone of you have any idea how I can model this in OpenFoam? I would be happy about every hint you can give me. Thank you very much in advance! Hope to help you too in the future Kind regards Markus |
moving parts, pipleflow |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Question on moving mesh, mesh velocity is really small! | ripperjack | Main CFD Forum | 2 | April 28, 2014 13:37 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 23, 2012 23:41 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
Moving mesh in Fluent | fivos | FLUENT | 0 | April 2, 2010 09:45 |
