November 19, 2017, 05:57 |
chtMultiRegionFoam- too slow
Sandy
Rep Power: 8 |
Hi to All,
I am trying to solve natural convection with conjugate heat transfer using chtMultiRegionFoam. Mesh inside domain is 160K only. I am using 0.001 time step size for solving. However with this set up, it is taking lot of time for solving. Case file is attached herewith for quick reference. Solver schemes of fluid region ,details of controldict and log output is given below. Certain lines of log output is also highlighted, where it seems problem. I am not sure,where I am going wrong. It is kind request to you all, please help me in this regard . Thanks fvSchemes for Fluid region Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss upwind; div(phi,K) Gauss linear; div(phi,h) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,R) Gauss upwind; div(R) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************************************* // Name of solvers for fluid region Code:
solvers { rho { solver PCG; preconditioner DIC; tolerance 1e-7; relTol 0.1; } rhoFinal { $rho; tolerance 1e-7; relTol 0; } p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother GaussSeidel; } p_rghFinal { $p_rgh; tolerance 1e-7; relTol 0; } "(U|h|k|epsilon|R)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-7; relTol 0.1; } "(U|h|k|epsilon|R)Final" { $U; tolerance 1e-7; relTol 0; } } PIMPLE { momentumPredictor yes; nCorrectors 2; nNonOrthogonalCorrectors 0; } relaxationFactors { equations { "h.*" 1; "U.*" 1; } } // Controldict file for solution Code:
application chtMultiRegionFoam; startFrom latestTime; startTime 0.0001; stopAt endTime; endTime 5; deltaT 0.0001; writeControl adjustableRunTime; writeInterval 0.001; purgeWrite 0; writeFormat ascii; writePrecision 8; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; maxCo 0.6; // Maximum diffusion number maxDi 10.0; adjustTimeStep yes; // Code:
Pimple iteration 0 Solving for fluid region fluidaround diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.4837011e-08, global = -1.8644987e-10, cumulative = 1.7575912e-06 DILUPBiCGStab: Solving for Ux, Initial residual = 0.048237251, Final residual = 1.088459e-08, No Iterations 3 DILUPBiCGStab: Solving for Uy, Initial residual = 0.016310354, Final residual = 1.9615561e-08, No Iterations 3 DILUPBiCGStab: Solving for Ux, Initial residual = 0.048237251, Final residual = 1.088459e-08, No Iterations 3 DILUPBiCGStab: Solving for Uz, Initial residual = 0.041151586, Final residual = 2.2887839e-08, No Iterations 3 DILUPBiCGStab: Solving for Uy, Initial residual = 0.016310354, Final residual = 1.9615561e-08, No Iterations 3 DILUPBiCGStab: Solving for Uz, Initial residual = 0.041151586, Final residual = 2.2887839e-08, No Iterations 3 DILUPBiCGStab: Solving for h, Initial residual = 0.01527495, Final residual = 4.3386867e-08, No Iterations 2 Min/max T:299.9994 300.00149 DILUPBiCGStab: Solving for h, Initial residual = 0.01527495, Final residual = 4.3386867e-08, No Iterations 2 DILUPBiCGStab: Solving for Ux, Initial residual = 0.048237251, Final residual = 1.088459e-08, No Iterations 3 Min/max T:299.9994 300.00149 DILUPBiCGStab: Solving for Uy, Initial residual = 0.016310354, Final residual = 1.9615561e-08, No Iterations 3 DILUPBiCGStab: Solving for Uz, Initial residual = 0.041151586, Final residual = 2.2887839e-08, No Iterations 3 DILUPBiCGStab: Solving for h, Initial residual = 0.01527495, Final residual = 4.3386867e-08, No Iterations 2 Min/max T:299.9994 300.00149 GAMG: Solving for p_rgh, Initial residual = 0.8569772, Final residual = 0.0058071545, No Iterations 9 GAMG: Solving for p_rgh, Initial residual = 0.8569772, Final residual = 0.0058071545, No Iterations 9 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.4837011e-08, global = -1.8644987e-10, cumulative = 1.7575912e-06 GAMG: Solving for p_rgh, Initial residual = 0.4402544, Final residual = 1.6539243e-06, No Iterations 1000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.4837011e-08, global = -1.8644987e-10, cumulative = 1.7575912e-06 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.1458128e-09, global = -3.6487898e-11, cumulative = 1.7577776e-06 Solving for solid region solidheater DICPCG: Solving for h, Initial residual = 0.9992465, Final residual = 5.1842275e-08, No Iterations 5 Min/max T:300.00141 300.00149 ExecutionTime = 3769.68 s ClockTime = 3822 s Region: fluidaround Courant Number mean: 5.0938106e-05 max: 0.10005987 Region: solidheater Diffusion Number mean: 0.62251892 max: 2.5951577 deltaT = 0.0005 Time = 0.011 Pimple iteration 0 Solving for fluid region fluidaround diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for p_rgh, Initial residual = 0.8569772, Final residual = 0.0058071545, No Iterations 9 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.4837011e-08, global = -1.8644987e-10, cumulative = 1.7575912e-06 DILUPBiCGStab: Solving for Ux, Initial residual = 0.048237251, Final residual = 1.088459e-08, No Iterations 3 DILUPBiCGStab: Solving for Uy, Initial residual = 0.016310354, Final residual = 1.9615561e-08, No Iterations 3 DILUPBiCGStab: Solving for Uz, Initial residual = 0.041151586, Final residual = 2.2887839e-08, No Iterations 3 DILUPBiCGStab: Solving for h, Initial residual = 0.01527495, Final residual = 4.3386867e-08, No Iterations 2 Min/max T:299.9994 300.00149 GAMG: Solving for p_rgh, Initial residual = 0.4402544, Final residual = 1.6539243e-06, No Iterations 1000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.1458128e-09, global = -3.6487898e-11, cumulative = 1.7577776e-06 Solving for solid region solidheater DICPCG: Solving for h, Initial residual = 0.9992465, Final residual = 5.1842275e-08, No Iterations 5 Min/max T:300.00141 300.00149 ExecutionTime = 3783.52 s ClockTime = 3830 s Region: fluidaround Courant Number mean: 5.0938106e-05 max: 0.10005987 Region: solidheater Diffusion Number mean: 0.62251892 max: 2.5951577 deltaT = 0.0005 Time = 0.011 Pimple iteration 0 Solving for fluid region fluidaround diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for p_rgh, Initial residual = 0.8569772, Final residual = 0.0058071545, No Iterations 9 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.4837011e-08, global = -1.8644987e-10, cumulative = 1.7575912e-06 DILUPBiCGStab: Solving for Ux, Initial residual = 0.048237251, Final residual = 1.088459e-08, No Iterations 3 DILUPBiCGStab: Solving for Uy, Initial residual = 0.016310354, Final residual = 1.9615561e-08, No Iterations 3 DILUPBiCGStab: Solving for Uz, Initial residual = 0.041151586, Final residual = 2.2887839e-08, No Iterations 3 DILUPBiCGStab: Solving for h, Initial residual = 0.01527495, Final residual = 4.3386867e-08, No Iterations 2 Min/max T:299.9994 300.00149 GAMG: Solving for p_rgh, Initial residual = 0.8569772, Final residual = 0.0058071545, No Iterations 9 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.4837011e-08, global = -1.8644987e-10, cumulative = 1.7575912e-06 GAMG: Solving for p_rgh, Initial residual = 0.4402544, Final residual = 1.6539243e-06, No Iterations 1000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.1458128e-09, global = -3.6487898e-11, cumulative = 1.7577776e-06 Solving for solid region solidheater DICPCG: Solving for h, Initial residual = 0.9992465, Final residual = 5.1842275e-08, No Iterations 5 Min/max T:300.00141 300.00149 ExecutionTime = 3802.89 s ClockTime = 3840 s Region: fluidaround Courant Number mean: 5.0938106e-05 max: 0.10005987 Region: solidheater Diffusion Number mean: 0.62251892 max: 2.5951577 deltaT = 0.0005 Time = 0.011 Pimple iteration 0 Solving for fluid region fluidaround diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCGStab: Solving for Ux, Initial residual = 0.048237251, Final residual = 1.088459e-08, No Iterations 3 DILUPBiCGStab: Solving for Uy, Initial residual = 0.016310354, Final residual = 1.9615561e-08, No Iterations 3 DILUPBiCGStab: Solving for Uz, Initial residual = 0.041151586, Final residual = 2.2887839e-08, No Iterations 3 DILUPBiCGStab: Solving for h, Initial residual = 0.01527495, Final residual = 4.3386867e-08, No Iterations 2 Min/max T:299.9994 300.00149 GAMG: Solving for p_rgh, Initial residual = 0.8569772, Final residual = 0.0058071545, No Iterations 9 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 1.4837011e-08, global = -1.8644987e-10, cumulative = 1.7575912e-06 GAMG: Solving for p_rgh, Initial residual = 0.41170003, Final residual = 2.2614473e-06, No Iterations 1000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 6.971801e-10, global = 1.7244533e-11, cumulative = 1.7576084e-06 Solving for solid region solidheater DICPCG: Solving for h, Initial residual = 0.99927812, Final residual = 5.1847013e-08, No Iterations 5 Min/max T:300.00149 300.00156 GAMG: Solving for p_rgh, Initial residual = 0.45318628, Final residual = 7.8711514e-07, No Iterations 1000 GAMG: Solving for p_rgh, Initial residual = 0.44200316, Final residual = 1.096905e-06, No Iterations 1000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 3.4963335e-09, global = 1.0997615e-10, cumulative = 1.7580701e-06 Solving for solid region solidheater DICPCG: Solving for h, Initial residual = 0.9994912, Final residual = 4.152597e-07, No Iterations 6 Min/max T:300.00113 300.00127 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 2.5994397e-09, global = -8.2721193e-11, cumulative = 1.7555659e-06 Solving for solid region solidheater DICPCG: Solving for h, Initial residual = 0.99936716, Final residual = 4.1521529e-07, No Iterations 6 Min/max T:300.00099 300.00113 GAMG: Solving for p_rgh, Initial residual = 0.41170003, Final residual = 2.2614473e-06, No Iterations 1000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 6.971801e-10, global = 1.7244533e-11, cumulative = 1.7576084e-06 Solving for solid region solidheater DICPCG: Solving for h, Initial residual = 0.99927812, Final residual = 5.1847013e-08, No Iterations 5 Min/max T:300.00149 300.00156 ExecutionTime = 4073.65 s ClockTime = 4080 s Region: fluidaround Courant Number mean: 5.3334931e-05 max: 0.10426789 Region: solidheater Diffusion Number mean: 0.62251892 max: 2.5951577 deltaT = 0.0005 Time = 0.0115 Pimple iteration 0 Solving for fluid region fluidaround diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for p_rgh, Initial residual = 0.44200316, Final residual = 1.096905e-06, No Iterations 1000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (fluidaround): sum local = 2.5994397e-09, global = -8.2721193e-11, cumulative = 1.7555659e-06 Solving for solid region solidheater DICPCG: Solving for h, Initial residual = 0.99936716, Final residual = 4.1521529e-07, No Iterations 6 Min/max T:300.00099 300.00113 DILUPBiCGStab: Solving for Ux, Initial residual = 0.028125658, Final residual = 4.8504238e-08, No Iterations 3 |
November 20, 2017, 04:29 |
Uwe Pilz
Rep Power: 15 |
It is not necessary to accept such a low Co number. Even in complicated cases 0.1 ... 0.01 is sufficient.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
November 20, 2017, 06:04 |
Sandy
Rep Power: 8 |
Hi Uwe,
Thanks for your reply and suggestion. I tried to increase time steps to 0.01s but it blows up solution after some time. Hence I tried to keep it too low. Any advice from your side? Boundary condition for fluidaround is given below. Fluidaround is cylinder, where top and bottom are flat portion and lateral is curved face of cylinder. Code:
U { internalField uniform (0 0 0); boundaryField { ".*" { type fixedValue; value uniform (0 0 0); } lateral { type fixedValue; value uniform (0 0 0); } top { type fixedValue; value uniform (0 0 0); } bottom { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } } } T { internalField uniform 300; boundaryField { ".*" { type zeroGradient; } top { type fixedValue; value uniform 300; } bottom { type inletOutlet; inletValue uniform 300; value uniform 300; } lateral { type fixedValue; value uniform 300; } "fluidaround_to_.*" { type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; kappaMethod fluidThermo; value uniform 300; } } } epsilon { internalField uniform 0.01; boundaryField { ".*" { type epsilonWallFunction; value uniform 0.01; } top { type fixedValue; value uniform 0.01; } lateral { type fixedValue; value uniform 0.01; } bottom { type inletOutlet; inletValue uniform 0.01; value uniform 0.01; } } } k { internalField uniform 0.1; boundaryField { ".*" { type kqRWallFunction; value uniform 0.1; } top { type fixedValue; value uniform 0.1; } lateral { type fixedValue; value uniform 0.1; } bottom { type inletOutlet; inletValue uniform 0.1; value uniform 0.1; } } } p_rgh { internalField uniform 1e5; boundaryField { ".*" { type fixedFluxPressure; value uniform 1e5; } bottom { type fixedValue; value uniform 1e5; } } } p { internalField uniform 1e5; boundaryField { ".*" { type calculated; value uniform 1e5; } bottom { type calculated; value uniform 1e5; } } } |
November 20, 2017, 07:53 |
Uwe Pilz
Rep Power: 15 |
I usual set maxCo in controlDict and lte the solver choose delta t.
adjustTimeStep yes; maxCo 1;
November 20, 2017, 18:51 |
Sandy
Rep Power: 8 |
Hi Uwe Pilz,
Thanks for the information. It works. Regards Sandeep |
conjugate heat transfer, natural convection |
heat transfer, multiple regions, chtMultiRegionFoam? | Ohlzen-Wendy | OpenFOAM Pre-Processing | 13 | February 8, 2022 07:17 |
Error in thermophysical properties (chtMultiRegionFoam) | mukut | OpenFOAM Pre-Processing | 28 | November 23, 2021 06:34 |
Fluent running increadibly slow | MayTheFlowBeWithYou | FLUENT | 12 | May 22, 2018 02:04 |
Calculation to slow | A.A. | OpenFOAM Running, Solving & CFD | 2 | January 10, 2013 04:44 |
Embed explicitSetValue in chtMultiRegionFoam | samiam1000 | OpenFOAM | 2 | April 18, 2012 05:14 |
