November 18, 2017, 16:36 |
Problem running atmBoundaryLayerInlet
Tommaso Pascon
Rep Power: 10 |
Hi everyone,
I'm having troubles running a simple 3D RANS flow over a cube. It works perfectly fine with uniform inlet velocity, but as soon as I use the atmBoundarylayerinlet for U and Epsilon, everything stop working. I simply copied the two files of the turbine tutorial in simpleFoam directory. These are mine U and Epsilon files: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows port by CFD support (www.cfdsupport.com) [based on Symscape] *\ \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0.01"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { buildings { type fixedValue; value uniform (0 0 0); } ground { type fixedValue; value uniform (0 0 0); } frontAndBack { type symmetry; } inlet { type atmBoundaryLayerInletVelocity; Uref 10.0; Zref 20; zDir (0 0 1); flowDir (1 0 0); z0 uniform 0.1; zGround uniform 935.0; value $internalField; } outlet { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows port by CFD support (www.cfdsupport.com) [based on Symscape] *\ \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0.01"; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 9.98e-06; boundaryField { buildings { type epsilonWallFunction; value uniform 9.98e-06; } ground { type epsilonWallFunction; value uniform 9.98e-06; } frontAndBack { type symmetry; } inlet { type atmBoundaryLayerInletEpsilon; Uref 10.0; Zref 20; zDir (0 0 1); flowDir (1 0 0); z0 uniform 0.1; zGround uniform 935.0; value $internalField; } outlet { type zeroGradient; } } // ************************************************************************* // smoothSolver: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for Uz, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 time step continuity errors : sum local = nan, global = nan, cumulative = nan smoothSolver: Solving for epsilon, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1000 ExecutionTime = 386.812 s ClockTime = 386 s forces forces output: sum of forces: pressure : (nan nan nan) viscous : (nan nan nan) porous : (0 0 0) sum of moments: pressure : (nan nan nan) viscous : (nan nan nan) porous : (0 0 0) forceCoeffs forceCoeffs output: Cm = nan Cd = nan Cl = nan Cl(f) = nan Cl(r) = nan fieldAverage fieldAverage1 output: Calculating averages Time = 5 What could be the issue? Thanks |
Problem About Running Fluent In Linux | mitra | FLUENT | 18 | June 20, 2019 02:11 |
Problem running angledDuct tutorial of porousSimpleFoam | Anindya1 | OpenFOAM Running, Solving & CFD | 0 | January 24, 2016 10:02 |
Non- stop running for a time-dependent heat source problem | Asghari_M | OpenFOAM Programming & Development | 1 | May 11, 2015 05:13 |
problem with running in parallel | dhruv | OpenFOAM | 3 | November 25, 2011 05:06 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
