November 14, 2017, 04:25 |
overInterDyMFoam mass default
Rep Power: 9 |
Hi foamers,
I am running a case of overInterDyMFoam with OpenFOAM v1706+ to use the overSetMesh specification. In this case a rotating container of water is supposed to pour the liquid inside a box through an other mesh cube. The container, the box and the mesh cube are in different mesh parts represented in the attached picture (picture 1) at time=0 seconds. The simulation runs, but the only trouble is that volume fraction of water (alpha) is not conserved; excess mass is produced while pouring. We can see this effect on the picture 2, above the rotating container. On the picture 3 and 4, we can see the calculation and remark that between the first time step and at T=9 seconds, the volume fraction increases from 0.00773351 to 0.00873013. I have checked all the process to build the simulation and I have not noticed any default. Has anybody faced the same problem ? Thank you, Best Regards |
February 2, 2018, 12:48 |
Ivan Fumagalli
This is definitely an important test to assess the suitability of the overSetMesh solvers: is there anyone else working on/with it, that could give more insight on the method employed, and its properties?
Thank you! |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Phi error in implimenting Kepsilon in DPMFoam | kinbean | OpenFOAM | 3 | December 19, 2017 18:11 |
Mass conservation error overInterDyMFoam (OF v.1706) | ngj | OpenFOAM Bugs | 6 | July 19, 2017 16:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
potentialFoam doesnt start?! | Sway | OpenFOAM Running, Solving & CFD | 0 | July 2, 2015 08:48 |
