Defining centre of mass/rotation in rigidBodyMotion solver |
November 9, 2017, 10:51 |
Owen Jones
I'm currently running a simple model of a boat hull moving at constant velocity on an initially flat free surface with interDyMFoam.
This is my dynamicMeshDict for the sixDoFRigidBodyMotion solver: Code:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libsixDoFRigidBodyMotion.so"); solver sixDoFRigidBodyMotion; sixDoFRigidBodyMotionCoeffs { patches (boat); innerDistance 0.2; outerDistance 1.2; centreOfMass (-3.2 0 0.7); mass 11000; momentOfInertia (4413 22295 20859); rhoInf 1; report on; //value uniform (0, 0, 0); accelerationRelaxation 0.05; accelerationDamping 0.9; solver { type Newmark; } } Code:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("librigidBodyMeshMotion.so"); solver rigidBodyMotion; rigidBodyMotionCoeffs { report on; solver { type Newmark; } accelerationRelaxation 0.05; accelerationDamping 0.9; bodies { boat { type rigidBody; parent root; centreOfMass (0 0 0); mass 11000; inertia (4413 0 0 22295 0 20859); transform (1 0 0 0 1 0 0 0 1) (-3.2 0 0.7); joint { type composite; joints ( { type Pz; } { type Ry; } ); } patches (boat); innerDistance 0.2; outerDistance 1.2; } } } |
November 26, 2018, 10:44 |
its transformational constraint in a simpler form
Vignesh S P
Rep Power: 8 |
i think thats a translational constraint in a combined form if u run the sixDoFRigidBodyMotion solver we have to specify the constraint under constraints funtion like highlighted below
motionSolverLibs ("libsixDoFRigidBodyMotion.so"); dynamicFvMesh dynamicOversetFvMesh; dynamicOversetFvMeshCoeffs { } solver sixDoFRigidBodyMotion; sixDoFRigidBodyMotionCoeffs { patches (floatingObject); innerDistance 100.0; outerDistance 101.0; centreOfMass (0 0 0); // Cuboid dimensions // Density of the solid rhoSolid 780; // Cuboid mass mass 0.40872; // Cuboid moment of inertia about the centre of mass momentOfInertia (1.21327e-05 1.21327e-05 1.21327e-05); velocity (0 0 0); report on; accelerationRelaxation 0.6; solver { type Newmark; } constraints { /*fixedPoint { sixDoFRigidBodyMotionConstraint point; centreOfRotation (0.5 0.45 0.1); }*/ /*fixedLine { sixDoFRigidBodyMotionConstraint line; //centreOfRotation (0.5 0.45 0.1); direction (0 0 1); }*/ /*fixedAxis { sixDoFRigidBodyMotionConstraint axis; axis (1 1 1); }*/ /*arrestRotation { sixDoFRigidBodyMotionConstraint orientation; }*/ } } while running the above the output log generated Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1806 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicOversetFvMesh Selecting motion solver: sixDoFRigidBodyMotion Selecting sixDoFSolver Newmark Translational constraint tensor (1 0 0 0 1 0 0 0 1) Rotational constraint tensor (1 0 0 0 1 0 0 0 1) PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Reading field p_rgh Reading field U Reading/calculating face flux field phi Creating cellMask field to block out hole cells |
centre of mass, dynamic mesh, interdymfoam, rigid body motion |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 17:08 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 07:58 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 17:25 |
Error during Solver | cfd guy | CFX | 4 | May 8, 2001 07:04 |
