hydraulic jump BC problen using interFoam
Old   November 8, 2017, 13:05
Default hydraulic jump BC problen using interFoam
Hao Zeng
Noémie is on a distinguished road
Dear users,
I'm taking a case where I found on the youtube for generating a hydraulic jump in a flat bottom. I'm using foam-extend-3.1. The original files I got from the poster on Youtube don't work for me (I think it is the version problem), so I made some changes to let the case running.
But the backwater can never reaches to the base flow, see the figures. (Fig.1 is the initial alpha1 and Fig.2 is the alpha1 after running 1s).
For the mesh, both inlet and outlet are seperated to water and air part.
Here is the BC for fields:
PHP Code:
alpha1:
boundaryField
inlet_water
type            fixedValue;
value           uniform 1;
inlet_air
type            outletInlet;
outletValue      uniform 0;
value           uniform 0;
outlet_water
type            inletOutlet;
inletValue      uniform 1;
value           uniform 0;
outlet_air
type            inletOutlet;
inletValue      uniform 0;
value           uniform 0;
atmosphere
type            zeroGradient;
walls
type            zeroGradient;
front
type            empty;
back
type            empty;
U:
boundaryField
inlet_water
type            fixedValue;
value           uniform (13 0 0);
inlet_air
type            pressureInletOutletVelocity;
value           uniform (0 0 0);
outlet_water
type            zeroGradient;
outlet_air
atmosphere
walls
type            fixedValue;
front
type            empty;
back
type            empty;
pd:
boundaryField
inlet_water
type            buoyantPressure;
gradient        uniform 0;
rho             rho;
value           uniform 0;
inlet_air
type            totalPressure;
rho             rho;
psi             none;
gamma           1;
p0              uniform 0;
value           uniform 0;
outlet_water
gradient        uniform 0;
rho             rho;
value           uniform 0;
outlet_air
type            totalPressure;
rho             rho;
psi             none;
gamma           1;
p0              uniform 0;
value           uniform 0;
walls
gradient        uniform 0;
rho             rho;
value           uniform 0;
atmosphere
type            totalPressure;
rho             rho;
psi             none;
gamma           1;
p0              uniform 0;
value           uniform 0;
"front|back"
type            empty;
I tried to change a lot with BC but it dosen't help. I do really need your help.
Thanks!
Hao
Noémie is offline   Reply With Quote
Problem modeling hydraulic jump in an open channel with interFoam (VoF) arnau1985 OpenFOAM Running, Solving & CFD 12 December 26, 2022 06:54
Stationary hydraulic jump - interFoam Bessy OpenFOAM Running, Solving & CFD 0 September 6, 2015 13:40
How to form hydraulic jump at specified location mojtabaivi FLOW-3D 5 August 13, 2015 05:22
Weird hydraulic jump with interFoam [SST k-omega] keepfit OpenFOAM Running, Solving & CFD 6 March 23, 2015 13:55
interFoam | Hydraulic Jump | Correct boundary condition p_rgh pythag0ra5 OpenFOAM Running, Solving & CFD 17 September 5, 2014 05:31
