Mesh setup for engineTopoChangerMesh class verticalValves
Old   November 7, 2017, 11:34
Default Mesh setup for engineTopoChangerMesh class verticalValves
Phibo is on a distinguished road
Hello Foamers,
I hope there is someone out there who can help me with the mesh setup for the engineTopoChangerMesh class verticalValves. I think I defined all the necessary boundary patches in the engineGeometry dictionary. However, the motion solver such as moveDyMEngineMesh (foam extend 4.0) gets stuck when the layer addtion/removal mesh modifiers are added:
Adding a layer addition/removal mesh modifier to the poppet of the valve 1
"valvePoppetLayer1"
1
Adding a layer addition/removal mesh modifier to the bottom of the valve 1
"valveBottomLayer1"
2
Adding a layer addition/removal mesh modifier to the piston-valve 1
--> FOAM FATAL ERROR:
Face extrusion zone contains no faces.  Please check your mesh definition.
    From function void Foam::layerAdditionRemoval::checkDefinition()
    in file polyMeshModifiers/layerAdditionRemoval/layerAdditionRemoval.C at line 123.
FOAM aborting
Does anybody know what is meant with "piston-valve"? I already went through the source and header files of verticalValves, but couldnīt figure it out. Any help would be much appreciated!
Thanks
Phibo is offline   Reply With Quote
engine simulation
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
