Oscillating lift coefficient in PimpleDyMFoam
Old   November 6, 2017, 16:26
Default Oscillating lift coefficient in PimpleDyMFoam
John P
Petr Kazarin is on a distinguished road
Hello colleagues,
I am modeling the fanwing in Openfoam (the fan embedded in between slat and airfoil).
I am using cyclicAMI etc - it works. The fan rotates with 400 rad/s and I get the transient solution.
However, the lift coefficient on slat and airfoil oscillates too much - almost from 1 to 10.. I calculated the mean value over time history and got smthg like 4.5 which is somewhat close to the value I got from Fluent. In fluent there are no such oscillations - the lift coefficient grows gradually up to 5.2-5.3 with very small oscillations.
I use SpalartAllmaras model. The freestreeam value is 15 m/s,
The fVSchemes I use is as follows:
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         cellLimited Gauss linear 1;
divSchemes
    default         none;
//    div(phi,U)      Gauss upwind;
    div(phi,U)      Gauss limitedLinear 1;//Gauss linearUpwind grad(U);//Gauss linearUpwind grad(U);
   // div(phi,k)      Gauss linear;//Gauss upwind;
   // div(phi,omega) Gauss linear;//Gauss upwind;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
    div(phi,nuTilda)  bounded Gauss linearUpwind grad(nuTilda);
laplacianSchemes
    default         Gauss linear limited corrected 0.33;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited corrected 0.33;
wallDist
method meshWave;
fvSolutions is:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    pcorr
        solver          GAMG;
      //  preconditioner  DIC;
        tolerance       1e-2;
        relTol          0;
        smoother        DICGaussSeidel;
        cacheAgglomeration no;
        maxIter         200;
    p
        $pcorr;
        tolerance       1e-5;
        relTol          0.01;
    Phi
        $p;
    pFinal
        $p;
        tolerance       1e-6;
        relTol          0;
    "(U|nuTilda)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        //solver          PBiCGStab;
      //  preconditioner  DILU;
        tolerance       1e-6;
        relTol          0.1;
    "(U|nuTilda)Final"
      // solver          PBiCGStab;
        tolerance       1e-6;
        relTol          0;
potentialFlow
    nNonOrthogonalCorrectors 10;
    PhiRefCell 0;
    PhiRefValue 0;
SIMPLE
nCorrectors     2;
nNonOrthogonalCorrectors 0;
    consistent yes;
PIMPLE
    correctPhi          no;
    nOuterCorrectors    3;
    nCorrectors         1;
    nNonOrthogonalCorrectors 1;
relaxationFactors
    U       0.5;
    UFinal  1;
cache
    grad(U);
I noticed that Residual for pressure is very high (up to 1).
Could you please give some advise of hot to suppress the residual for p ?
Petr Kazarin is offline   Reply With Quote
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 17:50
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Zero Coefficient of Lift Problem MH FLUENT 0 February 25, 2007 12:48
