simpleFoam and rhoSimpleFoam convergence problem |
Colombia
Rep Power: 13 ![]() |
I am trying to simulate a single-plug silencer. I am using rhoSimpleFoam to use the final result as initial condition for a sonicFoam simulation. The Mach number=0.05. The problem is that I could not have good residual values. When I run the simulation with simpleFoam it converges, but when I used a k-Eps or k-OmeSST the simulation crashes at 4 iterations with huge values on k and Epsilon (or Omega). With rhoSimpleFoam using laminar the simulation doesn't converge. I have tried modifying algorithms for pressure, k and Epsilon (omega) (GAMG, PBiCG, smoothSolver) and also modifying the relaxationFactors. I attach BC, fvSolution and fvSchemes. If anyone have any recommendation I will be really thankful. Thanks, Manuel |
rhosimplefoam, simplefoam convergence |
TRANSONIC FLOW in RHOSIMPLEFOAM | dinonettis | OpenFOAM Running, Solving & CFD | 10 | September 13, 2018 10:22 |
Switching from simpleFoam to rhoSimpleFoam | sebastian | OpenFOAM | 11 | January 7, 2015 04:32 |
SimpleFoam results as initial condition to rhoSimpleFoam | marcelorl | OpenFOAM Pre-Processing | 5 | March 7, 2014 10:08 |
Dimesion error after switching from simpleFoam to rhoSimpleFoam | sebastian | OpenFOAM Bugs | 2 | June 17, 2010 08:03 |
Problem with compressibility rhoSimpleFoam | gzink | OpenFOAM Running, Solving & CFD | 0 | August 3, 2006 13:50 |
