October 31, 2017, 03:00 |
rhoPimpleFoam rhoMin rhoMax
Oğuzhan Demir
Rep Power: 10 |
Greetings all,
I've been trying to work with rhoPimpleFoam solver for a while. Before that I was using sonicFoam without a problem. When i try to run the code, it explodes because rhoMin value gets too small (my threshold is rhoMin=0.01, and it becomes 0.01 after a few iterations and then explodes.) Any suggestion to rhoMin ? Thanks, Oguz |
October 31, 2017, 16:31 |
matej forman
Rep Power: 17 |
Well rhoMin parameter is OK. it helps you to control the solution. Is it physical for your solution to have rho lower than 0.01? If yes, set it lower, otherwise the problem will be (my humble guess) ill posed BCs or very unfavourable initial conditions. What about the min and max pressure? Reasonable?
November 2, 2017, 04:13 |
Oğuzhan Demir
Rep Power: 10 |
Thank you for your answer. I have solved the problem.
Oguz |
Velocity Oscillation with rhoPimpleFoam | McCharles | OpenFOAM | 0 | June 9, 2016 08:52 |
Pressure stair-step behaviour using rhopimplefoam | joegi.geo | OpenFOAM Running, Solving & CFD | 3 | December 12, 2014 13:10 |
what is the usage of "residualControl" in rhoPimpleFoam? | immortality | OpenFOAM Running, Solving & CFD | 1 | January 28, 2013 08:28 |
What are rhoMin and rhoMax in rhoPimpleFoam? | immortality | OpenFOAM Running, Solving & CFD | 8 | January 16, 2013 18:21 |
what is the purpose of rhoMin and rhoMax in fvsolution | mihaipruna | OpenFOAM Running, Solving & CFD | 3 | July 2, 2012 10:19 |
