Buoyancy Treatment in OpenFoam
Old   October 29, 2017, 11:35
Default Buoyancy Treatment in OpenFoam
AMK53 is on a distinguished road
From all the standard solvers that I found on OpenFoam, it seems that the buoyancy term is always treated by modifying the pressure:
-\nabla P + \rho g = -\nabla P_{rgh} - (g \cdot x) \nabla \rho
where
P_{rgh} = P - \rho g \cdot x
In OpenFoam format, this is usually written as
solve        (
            UEqn
            fvc::reconstruct
                  - ghf*fvc::snGrad(rho)
                  - fvc::snGrad(p_rgh)
                )*mesh.magSf()
Is there a particular numerical benefit for treating the buoyancy term in this fashion instead of just treating it as a source term \rho g? It seems to me this way is more complicated in the sense that you have to track two pressures (P and P_rgh), and for certain problems, creating an initial condition for P_rgh is not straightforward.
AMK53 is offline   Reply With Quote
Old   October 30, 2017, 05:31
Knut Erik T. Giljarhus
eric will become famous soon enough
Yes, using the modified pressure often makes the problem easier to handle numerically, and it's easier to specify boundary conditions.
eric is offline   Reply With Quote
Old   October 30, 2017, 23:51
Do you mind elaborating on how it makes it easier to handle numerically?
Old   October 31, 2017, 02:23
See this post on the issue tracker from Henry Weller, where he briefly explains it:
https://bugs.openfoam.org/view.php?id=1170
buoyancy, density, gravity
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
OpenFOAM wall function treatment kimotbwb OpenFOAM Programming & Development 7 March 6, 2015 13:52
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
OpenFOAM 2.x simpleFoam and kOmegaSST convergence and wall treatment gillimaniac OpenFOAM Running, Solving & CFD 6 August 1, 2013 02:36
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
