October 25, 2017, 21:28 |
mapFields function
Sungbae Lee
Rep Power: 9 |
I am reading OpenFoam tutorial and I don't understand mapFields. Guide says it maps fields from a case to another. tutorial has 2 cases cavityGrade and cavityFine. if I do cd $FOAM_RUN/cavityGrade mapFields ../cavityFine -consistent two cases have diffterent mesh geometry. Thank you. |
October 26, 2017, 02:32 |
#2 | |
CFDfreak
Rep Power: 10 |
-consistent indicates 'source and target geometry and boundary conditions identical'. So no problem if mesh sizes are different. Actually the purpose of mapFields is to run a case on coarse mesh first and map the solution into finer mesh. It is also helpful in identifying grid independence study. If you want to know more about mapFields try typing mapFields -help in terminal window. Thank you |
October 29, 2017, 20:06 |
Sungbae Lee
Rep Power: 9 |
Thank you! nandhakumar
Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 35 | June 21, 2019 10:54 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 07:59 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
