interFoam issue when changing OF 16.04 to 17.10
Old   October 24, 2017, 16:47
Default interFoam issue when changing OF 16.04 to 17.10
levogl is on a distinguished road
Dear All,
I am facing a problem what I unable to solve, and I hope someone of you already met this problem and knows the solution.
Base case: OpenFOAM, multiphase (2 phase) flow (interFoam solver), LES turbulence model, checkMesh says OK.
Problem:
- The case works well under OpenFOAM for Windows 17.06 (created under this)
- Exact the same case (with the necessary modifications what I know) does not work under OpenFOAM for Windows 17.10
I solved, the following issues when I adapted the case to OF for W 17.10:
1. after executing "setFields", alpha.fuel file does not carry the BC-s. But it set well the alpha for the internalField. I solved by manually editing the file, but it is strange I think.
2. The missing keyword "pcorrFinal" issue solved by replacing "pcorr" by "pcorr.*"
After these, in OF 17.10 interFoam start to run, but after the first loop, the solver blows up: residual of "k" is nan meanwhile the initial residual is 1.
I tried to change Co and maxAlphaCo, change tolerances of "k", "p_rgh", set more correctors for PIMPLE but none of them worked.
Did someone face such a problem? Can someone give me some advice what would be the problem?
Log of interFoam:
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type LES
Selecting LES turbulence model kEqn
Selecting LES delta type smooth
Selecting LES delta type cubeRootVol
kEqnCoeffs
    Ce              1.048;
    Ck              0.094;
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 3.388116e-006, No Iterations 11
GAMGPCG:  Solving for pcorr, Initial residual = 0.04278774, Final residual = 2.661251e-006, No Iterations 4
GAMGPCG:  Solving for pcorr, Initial residual = 0.002614785, Final residual = 5.884809e-006, No Iterations 3
GAMGPCG:  Solving for pcorr, Initial residual = 0.0002990128, Final residual = 3.12335e-006, No Iterations 1
GAMGPCG:  Solving for pcorr, Initial residual = 4.117763e-005, Final residual = 9.902944e-007, No Iterations 1
GAMGPCG:  Solving for pcorr, Initial residual = 7.23902e-006, Final residual = 7.23902e-006, No Iterations 0
time step continuity errors : sum local = 6.399441e-008, global = -1.069007e-009, cumulative = -1.069007e-009
Courant Number mean: 0.004253773 max: 0.8613923
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.01
Time = 0.01
PIMPLE: iteration 1
MULES: Solving for alpha.fuel
Phase-1 volume fraction = 0.003936036  Min(alpha.fuel) = 0  Max(alpha.fuel) = 1.000025
Phase-1 volume fraction = 0.003950298  Min(alpha.fuel) = 0  Max(alpha.fuel) = 1.000049
Phase-1 volume fraction = 0.003964559  Min(alpha.fuel) = 0  Max(alpha.fuel) = 1.000071
Phase-1 volume fraction = 0.003978821  Min(alpha.fuel) = 0  Max(alpha.fuel) = 1.000091
GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 6.973166e-008, No Iterations 29
GAMG:  Solving for p_rgh, Initial residual = 0.04714752, Final residual = 6.365322e-008, No Iterations 16
GAMG:  Solving for p_rgh, Initial residual = 0.003511602, Final residual = 7.682389e-008, No Iterations 12
GAMG:  Solving for p_rgh, Initial residual = 0.0003714307, Final residual = 9.656306e-008, No Iterations 6
GAMG:  Solving for p_rgh, Initial residual = 4.977958e-005, Final residual = 7.345298e-008, No Iterations 5
GAMG:  Solving for p_rgh, Initial residual = 7.690884e-006, Final residual = 7.099504e-008, No Iterations 2
time step continuity errors : sum local = 1.331502e-007, global = 3.895548e-008, cumulative = 3.788647e-008
GAMG:  Solving for p_rgh, Initial residual = 0.4310846, Final residual = 7.909259e-008, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.02048172, Final residual = 6.497497e-008, No Iterations 13
GAMG:  Solving for p_rgh, Initial residual = 0.001358718, Final residual = 6.007829e-008, No Iterations 9
GAMG:  Solving for p_rgh, Initial residual = 0.000130214, Final residual = 7.332109e-008, No Iterations 5
GAMG:  Solving for p_rgh, Initial residual = 1.497639e-005, Final residual = 5.772462e-008, No Iterations 3
GAMGPCG:  Solving for p_rgh, Initial residual = 2.274067e-006, Final residual = 5.105044e-008, No Iterations 1
time step continuity errors : sum local = 8.880562e-008, global = 1.647652e-008, cumulative = 5.436299e-008
smoothSolver:  Solving for k, Initial residual = 1, Final residual = nan, No Iterations 1000
ExecutionTime = 6.525 s  ClockTime = 6 s
levogl is offline   Reply With Quote
interFoam and cyclic boundary condition issue General_Gee OpenFOAM Running, Solving & CFD 17 October 8, 2018 10:33
interFoam stability issue, free surface ship hull jojosaxo OpenFOAM Running, Solving & CFD 5 July 7, 2016 18:29
Problem of InterFoam with LES SpalartAllmarasIDDES keepfit OpenFOAM 3 August 29, 2013 12:21
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 09:27
Runing InterFoam for 3 D damBreak case Patch issue nishant_hull OpenFOAM Running, Solving & CFD 5 February 18, 2009 01:32
