wallHeatFlux with radiation
Old   October 16, 2017, 17:30
Default wallHeatFlux with radiation
ff
fxzf is on a distinguished road
Hi Everyone,
I got a bit trouble in Openfoam with heat transfer problem. Basically, I need to specify heatflux boundary condition which is same with Fluent. However, I didn't find this boundary condition in standard Openfoam. I found a "externalWallHeatFluxTemperature", but that is for compressible flow with solid. My case is incompressible flow with buoyantboussinesqsimplefoam solver.
Then, luckily, I download a wallHeatFlux boundary condition from foam contribution.
https://openfoamwiki.net/index.php/Contrib/wallHeatFlux
However, this one is not included radiation. So, I test it for radiation off case, the results is almost identical with Fluent.
Then, I added radiation in it. So basically, I just added qr in the equation
gradient() = (HeatFlux_ - qr_)/(alphaEffW * Cp0.value() * rho0.value() );
The code is working when radiation on. However, it then crashed very soon as G (radiation incident), T temperature are goto very high number like E100 then crashed.
Does anyone know anything about Heatflux boundary condition to give me any suggestion?
Thanks a lot.
fxzf is offline   Reply With Quote
Old   October 25, 2017, 12:55
ff
Hi Guys,
I added relexation factor for qr in this case, and it then working. However, the relaxation factor is related to qr magnitude when qr is high, very low relaxation is needed like 1E-5. However, this will make simulation converge very very slow.
Does anyone has any idea to improve convergence?
Thanks a lot.
wallHeatFlux and radiation craig.tickle OpenFOAM Post-Processing 5 December 2, 2018 09:00
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation Zeppo OpenFOAM Running, Solving & CFD 16 May 18, 2017 19:04
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 06:41
Radiation Modeling Chris89 CFX 20 August 14, 2014 08:51
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
