rhoCentralFoam diverges
Old   October 16, 2017, 04:07
Default rhoCentralFoam diverges
Dorian1504 is on a distinguished road
I'm currently trying to simulate an inviscid supersonic (Mach 3) flow around rocket (agard-B) with rhoCentralFoam however the solver crashes after few iterations.
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
fluxScheme: Kurganov
Starting time loop
Mean and max Courant Numbers = 0.00140598 0.446339
Time = 0.0001
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal:  Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
ExecutionTime = 32.94 s  ClockTime = 34 s
Mean and max Courant Numbers = 0.00140598 0.449586
Time = 0.0002
ExecutionTime = 43.17 s  ClockTime = 44 s
Mean and max Courant Numbers = 0.00140598 0.452832
Time = 0.0003
ExecutionTime = 53.8 s  ClockTime = 55 s
Mean and max Courant Numbers = 0.00140598 0.455672
Time = 0.0004
ExecutionTime = 64.03 s  ClockTime = 65 s
Mean and max Courant Numbers = 0.00140598 0.457651
Time = 0.0005
ExecutionTime = 74.42 s  ClockTime = 75 s
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5  ? at ??:?
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7  ? at ??:?
Floating point exception (core dumped)
My files :
U
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 1041 0);
boundaryField
    box
        type            slip;
    inlet
        type            supersonicFreestream;
        pInf            100000;
        TInf            300;
        UInf            (0 1041 0);
        gamma           1.4;
        value           uniform (0 1041 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 1041 0);
    agardB
        type            slip;
p
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 100000;
boundaryField
    box
        type            zeroGradient;
    inlet
        type            zeroGradient;
    outlet
        type            waveTransmissive;
        field           p;
        psi             thermo:psi;
        gamma           1.3;
        fieldInf        100000;
        lInf            1;
        value           uniform 100000;
    agardB
        type            zeroGradient;
T
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    inlet
        type            inletOutlet;
        inletValue      uniform 300;
        value           uniform 300;
    outlet
        type            inletOutlet;
        value           uniform 300;
    box
        type            zeroGradient;
    agardB
        type            zeroGradient;
controlDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     rhoCentralFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.5;
deltaT          1e-4;
writeControl    runTime;
writeInterval   0.02;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
graphFormat     raw;
runTimeModifiable false;
adjustTimeStep  no;
maxCo           0.5;
maxDeltaT       2e-4
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "(rho|rhoU|rhoE)"
        solver          diagonal;
    U
        solver          smoothSolver;
        smoother        GaussSeidel;
        nSweeps         2;
        tolerance       1e-09;
        relTol          0.01;
    h
        $U;
        tolerance       1e-10;
        relTol          0;
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
fluxScheme      Kurganov;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(tauMC)      Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
    reconstruct(rho) vanLeer;
    reconstruct(U)  vanLeerV;
    reconstruct(T)  vanLeer;
snGradSchemes
    default         corrected;
I tried running in subsonic with U=10 m/s and rhoCentralFoam didn't diverge.
I also tried to reduce the time step but it always diverges a the same time, near 0.0005s.
My courant number is ok.
I can't figure out why the simulation doesn't work. Do you have any idea ?
Thank you
Dorian
Dorian1504 is offline   Reply With Quote
Old   November 1, 2017, 04:42
Default 3D simulation on rhoCentralFoam
openfoam
lvha is on a distinguished road
I have the same problem when run 3d simulation on rhoCentralFoam.
lvha is offline   Reply With Quote
Old   November 1, 2017, 06:19
matej forman
matejfor is on a distinguished road
I'm not any compressible flow expert, but briefly looking at your log, the solver does not solve a single time for a single variable - there is nothing going on in your simulation.
My humble guess would be ill posed BCs.
Matej
matejfor is offline   Reply With Quote
Old   December 9, 2017, 21:39
dli
dengli
dli is on a distinguished road
[QUOTE=Dorian1504;668031]Hello,
Create time
    type            hePsiThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
Reading field U
Starting time loop
Time = 0.0001
Time = 0.0002
Time = 0.0003
Time = 0.0004
Time = 0.0005
#5  ? at ??:?
#7  ? at ??:?
The line "#3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:?" may be point of the problem, which means that a negative number in the sqrt() operation.
dli is offline   Reply With Quote
Old   December 10, 2017, 15:22
Taher Chegini
Taataa is on a distinguished road
for the inlet you should use outletInlet and for outlet, inletOutlet.
Also, in the solver I suggest to use relTol of 0 for U. diagonal solver is used for explicit systems, make sure that you're using it correctly.
Taataa is offline   Reply With Quote
How to apply a turbulence model to the rhoCentralFoam solver? arussell92 OpenFOAM Pre-Processing 18 July 25, 2022 05:26
Modify rhoCentralFoam: other equations of state fivos OpenFOAM Programming & Development 5 July 29, 2020 14:17
rhocentralFoam Diverges!!? sasanghomi OpenFOAM Running, Solving & CFD 5 April 19, 2014 03:38
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 09:00
rhoCentralFoam solver with Slip BCs fails in Parallel Only JLight OpenFOAM Running, Solving & CFD 2 October 11, 2012 22:08
