How to select certains faces to calculate lift coefficient?
Old   October 12, 2017, 16:20
Default How to select certains faces to calculate lift coefficient?
Xiaojie Wang
xuankushuocai is on a distinguished road
Hi guys,
I want to calculate the lift coefficient of a model with a fan patch created in OpenFOAM. The problem is that I don't want to calculate the lift force on the fan patch. Who knows how to recognize different types of surfaces or select surfaces to do the calculation? Thanks.
xuankushuocai is offline   Reply With Quote
Old   October 13, 2017, 04:18
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
If you calculate forces using the forces function object you can choose over which patches to integrate:
https://cpp.openfoam.org/v4/classFoa...s.html#details
kandelabr is offline   Reply With Quote
Old   October 15, 2017, 10:43
JPeternel
jpeter3 is on a distinguished road
You can code it into the solver as follows:
You can access the boundary field using .boundaryField().
That returns an array of fields, one for each patch.
You can identify patchID of your patch by using .findPatchID("nameOfThePatch") that Will be used to acces the one you need.
Looping through boundary field of selected patch you can access data on the faces on that patch to calculate what you want.
Like this:
//Find patch ID for your patch:
label patchID = mesh.boundaryMesh().findPatchID("yourPatchName");
//Store face IDs of your patch:
const polyPatch& cPatch = mesh.boundaryMesh()[patchID];
//Field you want to extract values from:
const someFieldType& yourFieldRef = yourField
//Loop over face IDs of faces that are located on your patch:
forAll(cPatch, facei)
//Data you seek:
scalar/vector... data = yourFieldRef.boundaryField()[patchID][facei];
jpeter3 is offline   Reply With Quote
Old   October 16, 2017, 13:49
Xiaojie Wang
Hi, Nejc and Jaka, thanks a lot. I have figured it out.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
[snappyHexMesh] SHM is not extruding/adding Layers everywhere matthiasd OpenFOAM Meshing & Mesh Conversion 2 October 16, 2016 17:45
How can I calculate force for lift coefficient and drag coefficient ? gemxx CFX 3 July 4, 2015 09:37
how can i calculate the lift and drag coefficient yujun Main CFD Forum 5 January 23, 2003 16:16
