October 10, 2017, 04:45 |
pisoFoam-wrong results?
Jingxue Wang
Rep Power: 9 |
I am calculating the flat building pressure in a wind tunnel.The model is just a cubic building inside a large cuboid wind tunnel. I used pisoFoam to solve and the LES Smagorinsky sub-grid model was adopted.The velocity of inlet boudary condition is turbulentInlet with fluctuation around 2m/s average wind speed.I improved the mesh for some times and the mesh quality is ok after I used checkMesh( shown in the followings).But the courant number becomes suddenly large and the caculation stoped at around 0.04s.I am really get caught in this and did not find the reason for this.The followings are the setups of my calculation.Could you please check them?Do you think the boundary conditions or discetisation schemes are reasonable?
I am really appreciate if somebody can give me any corrections or suggestions.Thanks!!! 0/p: Code:
dimensions [0 2 -2 0 0 0 0]; //*****Units: m2s-2 dynamic pressure=pressure/density*****// internalField uniform 0; boundaryField { INLET { type zeroGradient; } OUTLET { //type zeroGradient; type fixedValue; value uniform 0; } LEFT { // type zeroGradient; type symmetryPlane; } RIGHT { // type zeroGradient; type symmetryPlane; } UP { // type zeroGradient; type symmetryPlane; } GROUND { type zeroGradient; } ROOF { type zeroGradient; } WINDWARD { type zeroGradient; } BACKWARD { type zeroGradient; } LEFTWARD { type zeroGradient; } RIGHTWARD { type zeroGradient; } } Code:
dimensions [0 1 -1 0 0 0 0];//*****Units:m/s*****// internalField uniform (0 0 0); boundaryField { INLET { type turbulentInlet; referenceField uniform (2 0 0); fluctuationScale (0.02 0.01 0.01); value uniform (2 0 0); } OUTLET { type zeroGradient; } LEFT { type symmetryPlane; //type fixedValue; //value uniform (0 0 0); } RIGHT { type symmetryPlane; //type fixedValue; //value uniform (0 0 0); } UP { type symmetryPlane; // type fixedValue; // value uniform (0 0 0); } GROUND { type fixedValue; value uniform (0 0 0); } ROOF { type fixedValue; value uniform (0 0 0); } WINDWARD { type fixedValue; value uniform (0 0 0); } BACKWARD { type fixedValue; value uniform (0 0 0); } LEFTWARD { type fixedValue; value uniform (0 0 0); } RIGHTWARD { type fixedValue; value uniform (0 0 0); } } Code:
ddtSchemes { default backward; //default CrankNicolson 0.9; } gradSchemes { default leastSquares; //grad(p) Gauss linear; } divSchemes { default none; div(phi,U) Gauss LUST grad(U); div(phi,k) Gauss limitedLinear 1; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } Code:
solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 2; pRefCell 0; pRefValue 0; } Code:
simulationType LES; LES { LESModel Smagorinsky; turbulence on; printCoeffs on; delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } } |
October 10, 2017, 05:52 |
Oskar
Rep Power: 11 |
Hello. In my opinion courant number is too high.
Set Your deltaT in controlDict to 0.0005 to keep Courant Number around 1. Also Your "Mesh non-orthogonality Max: 63.7369" And: "nNonOrthogonalCorrectors 2;" Could makes some troubles. In my case I have non orthogonality max ~ 70 and: "nNonOrthogonalCorrectors 6;" At the beginning set Your parameters of piso loop on high values (fo example 5 nCorrectors and 10 nNonOrthogonalCorretors) and start simulation. Then try to lower them as much as possible until divergence occurs. You know the rest. Have a nice day. Sheaker |
October 10, 2017, 06:43 |
#3 | |
Jingxue Wang
Rep Power: 9 |
Thanks for your suggestion. The minimum grid size is 0.01, and the inlet velocity is 2m/s. So to make the Co around 1, delta t=0.05 was adopted. The courant number is around 7 for the first steps but then increased suddenly. So more delta t should be adpoted? Before, I tried to decrease the delta t to one order of magnitude(not for this case), it can continues more time steps but it also divergenced eventually. I will increase nNonOrthogonalCorrectors and nCorrectors in PISO. Many thanks for your help!I really appcreciate it. |
October 10, 2017, 08:00 |
Jingxue Wang
Rep Power: 9 |
I decreased delta t to 0.0005 and increased nCorrectors and nNonOrthonalCorrectors to 6. But it stoped at the 3rd time step.
Maybe the boundary conditions are not reasonble? Do somebody has such experience? |
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 21:49 |
wrong results after use UDF turbulent viscosity | lehoanganh07 | Fluent UDF and Scheme Programming | 0 | July 21, 2014 12:12 |
porous media turbulent model P-dL, I get the different results? is the model wrong? | hitchenxue | FLUENT | 0 | July 13, 2014 06:57 |
Comparing Air numerical results with water experimental results | cristian2009es | Main CFD Forum | 1 | July 2, 2014 19:11 |
I got complete different results for pisofoam and pimplefoam? | lakeat | OpenFOAM Running, Solving & CFD | 6 | December 27, 2012 05:25 |
