Periodic cyclic AMI + MRF crashing on pressure |
Thomas Sprich
Rep Power: 11 ![]() |
Dear FOAMERS
I am simulating a 3D impeller case in a closed tank (no inlet and outlet) with simpleFOAM and MRF. I would like to take advantage of symmetry. To do this I model the geometry of the tank in quarters along the axis of the tank as shown in the image. I am using cyclicAMI boundary conditions on the ‘wedge’ edges because I can’t get an equal mesh on each face. When I run simpleFOAM, I get a crash on the first iteration on the pressure step. See the error below: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : simpleFoam Date : Oct 09 2017 Time : 08:53:30 Host : "thomas-MS-7885" PID : 3752 Case : FourBladedMapFieldsRealizeableKEHiResCyclic nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Overriding DebugSwitches according to controlDict coupled 1; Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.0001 field U tolerance 1e-05 field "(k|epsilon)" tolerance 1e-05 Reading field p AMI: Creating addressing and weights between 50097 source faces and 44472 target faces AMI: Patch source sum(weights) min/max/average = 0, 2.4426, 1.0002 AMI: Patch target sum(weights) min/max/average = 0.26519, 2.476, 1.0029 Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model realizableKE bounding k, min: 0 max: 0.051 average: 0.051 bounding epsilon, min: 0 max: 0.05 average: 0.05 Creating MRF zone list from MRFProperties creating MRF zone: MRF1 No finite volume options present Starting time loop Time = 1 GAMG: Solving for Ux, Initial residual = 1, Final residual = 2.2586e-05, No Iterations 3 GAMG: Solving for Uy, Initial residual = 1, Final residual = 0.00090351, No Iterations 2 GAMG: Solving for Uz, Initial residual = 1, Final residual = 0.00082893, No Iterations 2 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Does anyone have some advice on how to resolve this? My boundary conditions are: p: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { cyclic1-Right { type cyclicAMI; } cyclic2-Left { type cyclicAMI; } rotorBottom { type zeroGradient; } baffles { type zeroGradient; } tank { type zeroGradient; } shaft { type zeroGradient; } bottomOfTank { type zeroGradient; } topOfTank { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { cyclic1-Right { type cyclicAMI; } cyclic2-Left { type cyclicAMI; } rotorBottom { type fixedValue; value uniform (0 0 0); } baffles { type fixedValue; value uniform (0 0 0); } tank { type fixedValue; value uniform (0 0 0); } shaft { type fixedValue; value uniform (0 0 0); } bottomOfTank { type fixedValue; value uniform (0 0 0); } topOfTank { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.051; boundaryField { cyclic1-Right { type cyclicAMI; } cyclic2-Left { type cyclicAMI; } rotorBottom { type kqRWallFunction; value uniform 0.051; } baffles { type kqRWallFunction; value uniform 0.051; } tank { type kqRWallFunction; value uniform 0.051; } shaft { type kqRWallFunction; value uniform 0.051; } bottomOfTank { type kqRWallFunction; value uniform 0.051; } topOfTank { type kqRWallFunction; value uniform 0.051; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volScalarField; location "0"; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.05; boundaryField { cyclic1-Right { type cyclicAMI; } cyclic2-Left { type cyclicAMI; } rotorBottom { type epsilonWallFunction; value uniform 0.05; } baffles { type epsilonWallFunction; value uniform 0.05; } tank { type epsilonWallFunction; value uniform 0.05; } shaft { type epsilonWallFunction; value uniform 0.05; } bottomOfTank { type epsilonWallFunction; value uniform 0.05; } topOfTank { type epsilonWallFunction; value uniform 0.05; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 8 ( rotorBottom { type wall; inGroups 1(wall); nFaces 27410; startFace 2887555; } baffles { type wall; inGroups 1(wall); nFaces 8790; startFace 2914965; } tank { type wall; inGroups 1(wall); nFaces 23866; startFace 2923755; } shaft { type wall; inGroups 1(wall); nFaces 2813; startFace 2947621; } bottomOfTank { type wall; inGroups 1(wall); nFaces 7259; startFace 2950434; } topOfTank { type wall; inGroups 1(wall); nFaces 7268; startFace 2957693; } cyclic1-Right { type cyclicAMI; inGroups 1(cyclicAMI); nFaces 50097; startFace 2964961; matchTolerance 0.0001; transform rotational; neighbourPatch cyclic2-Left; rotationAxis (0 0 1); rotationCentre (0 0 0); } cyclic2-Left { type cyclicAMI; inGroups 1(cyclicAMI); nFaces 44472; startFace 3015058; matchTolerance 0.0001; transform rotational; neighbourPatch cyclic1-Right; rotationAxis (0 0 1); rotationCentre (0 0 0); } ) // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { //default faceLimited leastSquares 0.5; default Gauss linear; //grad(p) cellLimited Gauss linear 1; //grad(U) cellLimited Gauss linear 1; } divSchemes { default none; //div(phi,U) bounded Gauss limitedLinearV 1; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss linearUpwind grad(U); div(phi,epsilon) bounded Gauss linearUpwind grad(U); div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { // default Gauss linear corrected; default Gauss linear limited 0.33; } interpolationSchemes { default linear; } snGradSchemes { // default limited 0.33; default corrected; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; relTol 0.01; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } pFinal { $p; relTol 0.00; } U { solver GAMG; tolerance 1e-08; relTol 0.001; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; } k { solver GAMG; smoother GaussSeidel; nSweeps 5; tolerance 1e-08; relTol 0.001; } epsilon { solver GAMG; smoother GaussSeidel; nSweeps 5; tolerance 1e-08; relTol 0.001; } } SIMPLE { nNonOrthogonalCorrectors 2; momentumPredictor yes; pRefCell 0; pRefPoint (00 0.0); pRefValue 0; residualControl { p 1e-4; U 1e-5; "(k|epsilon)" 1e-5; } } relaxationFactors { fields { p 0.7; } equations { U 0.6; k 0.6; epsilon 0.6; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object MRFProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // MRF1 { cellZone rotatingDomainBottom; active yes; // Fixed patcsshes (by default they 'move' with the MRF zone) nonRotatingPatches (cyclic1-Right cyclic2-Left); origin (0 0 0); axis (0 0 1); omega -2.8571; } // ************************************************************************* // Kind Regards, Thomas Sprich |
Rep Power: 16 ![]() |
If you look at the weights of your AMI, you see that the minimum weight is 0. While I have not performed simulations similar to yours, I have encountered AMI issues in my runs & they typically have to do with the minimum weight being 0. This 0 weight, at least for me, has been the result of there being a mismatch in defining the cyclicAMI patches. You might want to check your mesh, particularly the AMI faces/patches, to ensure that the patches are defined correctly Hope this helps. Cheers, Antimony |
Thomas Sprich
Hi Antimony,
Thanks for your reply. It makes sense what you say. I think when I saw it crash on pressure, on not on velocity that AMI weights were not a problem. I'm not sure what type of AMI simulations you have done. I've done some where I had rotating AMI planes and AMI was a problem too. In this case, the AMI planes are orthogonal and I'm not sure if that could be the problem...? There is a 'rotationAngle' option available for the cyclicAMI definition, but I'm not sure how to use this. The second thing that could be a problem is at the corner of the wedge by the axis where the two AMI planes meet the mesh is very busy because this is where the impeller is located. I can't think why this should be a problem, but I think it is worth mentioning. Thomas |
Thomas Sprich
Hi Antimony,
I have remeshed while trying to get better AMI weights. I have managed to get the following when running simpleFoam: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Overriding DebugSwitches according to controlDict coupled 1; Create mesh for time = 1 SIMPLE: convergence criteria field p tolerance 0.0001 field U tolerance 1e-05 field "(k|epsilon)" tolerance 1e-05 Reading field p AMI: Creating addressing and weights between 61954 source faces and 61950 target faces AMI: Patch source sum(weights) min/max/average = 0.5618, 1.1697, 1 AMI: Patch target sum(weights) min/max/average = 0.562, 1.0172, 0.99997 The weights are not close to one. Is this a problem? At least they are very similar. Thanks for your help once again. Thomas |
I think most of the problems come only when the weights are exactly 0. Apart from that the simulation should run, though there is no guarantee that it won't fail later. If I remember correctly (from reading somewhere), if you use the rotation transformation, then it is quite possible that you will weights that are not close to 1 (but I could be wrong!). Apologies that I don't have a more definitive answer for you. Cheers, Antimony |
Thomas Sprich
Hi Antimony,
Just to let you know. The simulation ran to a reasonable convergence without crashing. Thanks again for your help and swift responses. Thomas |
Kmeti Rao
Rep Power: 8 ![]() |
Hi Thomas Sprich,
I am facing a similar problem where the patch AMI weights are zero. I am trying to simulate half of the propeller using MRF+AMI. It would be very interesting if you can share the information regarding what exactly was the error that caused the failure. Thank you |
Thomas Sprich
Hi Krao,
Its been a long time since I have done this. To be honest, I think at that stage I just played with sHM settings until I got better AMI weights. Since then I have found some tips that can help get better results. The problem I had was that the points on the master and slave surfaces for the AMI surfaces where not 100% conformal. You can see this when you look at them in paraFoam, the surfaces don't quite line up. I particularly had a problem at the edges. To be able to help, you would really need to show your snappyHexMeshDict and show your meshing procedure. You also haven't shown what your error is, are all your AMI weights zero, or just the minimum? I can only presume what problems you are having, but the below has helped me get AMI surfaces with better weights. Assuming that you have had similar problems to me. There is a really good example for how to get good AMI surfaces in the tutorials: tutorials/compressible/rhoPimpleFoam/RAS/annularThermalMixer/system/ I recommend starting with this. Unlike in the propeller tutorial in pimple(DyM)Foam, here no facetype is defined and mergeOrSplitBaffles is used. I have honestly found this to be the only way to get AMI surfaces that are 100% conformal and that allow me to rotate the mesh. But you aren't rotating your mesh, so this maybe isn't an issue for you. This may also help you: https://openfoam.org/release/2-2-0/s...fles/#x4-12000 See "Baffle and Boundary Creation" section. This may also give you some ideas. I hope that helps, Thomas |
#9 |
Kmeti Rao
Thank you very much for your reply, can you please look into this thread, which I have posted yesterday (One half propeller simulation with MRFSimpleFoam crashing). It would be of a great help if you can provide some insights, where I would have made mistakes.
Previously I have used, AMI successfully for the dynamic simulation of Propellers and also I had success with MRFsimpleFoam for the full propeller. Now I am trying to figure out a procedure for determining the results of one half propeller, to save computational time. |
cyclicami; mrf |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
