problem with forwardStep tutorial
Old   October 3, 2017, 18:16
Default problem with forwardStep tutorial
Носов Геннадий А
Gena is on a distinguished road
Hello. I had a problem with the forwardStep example. it is normally considered with the original data, but if I specify T = 300 p = 101000 and v = 600 it gives an error that T <0 in the calculation process. How to avoid this?
--> FOAM FATAL ERROR:
Negative initial temperature T0: -1625.03
From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam:erfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam:er fectGas<Foam::specie> >, Foam::sensibleInternalEnergy>]
in file /opt/CFDSupportFOAM4.0/beta/OpenFOAM-dev/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 54.
FOAM aborting
Gena is offline   Reply With Quote
cavity tutorial problem in OF 3.0.x mohsen.boojari OpenFOAM Running, Solving & CFD 5 February 14, 2016 12:03
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
newbie problem with cavity tutorial miki OpenFOAM Running, Solving & CFD 8 September 2, 2012 16:22
Problem with the Fan tutorial widedMed OpenFOAM 3 March 29, 2011 05:35
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 03:32
