fluent3DMeshToFoam - (periodic) cyclic boundary
Old   October 2, 2017, 00:19
Default fluent3DMeshToFoam - (periodic) cyclic boundary
cyln
cyln is on a distinguished road
My computational domain has a shape of slice of a cylinder. I have generated my mesh on this domain using ICEM. Two sides are defined as periodic boundaries. However, when I use fluent3DMeshToFoam to convert the mesh in OpenFOAM, the software faces issues due to the periodic (cyclic) boundary.
A suggested alternative way is to define these periodic boundaries, lets say as symmetry boundaries, then convert the mesh using fluent3DmeshToFoam. Then you use createPatch funtion ( via createPatchDict file) to convert your symmetry boundaries to cyclic boundaries.
I performed these steps. I modified createPatchDict file as suggested. When I run createPatch, at the beginning, it works fine but I get the following error at the end.
> FOAM FATAL ERROR:
For patch SIDE11 there are 159185 face centres, for the neighbour patch SIDE22 there are 160271
From function void Foam::cyclicPolyPatch::calcTransforms(const primitivePatch&, const pointField&, const vectorField&, const pointField&, const vectorField&)
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 156.
FOAM exiting
Obviously, the number of face centres are different on each side. Is there any way to get rid of this problem? I would appreciate any suggestion
Cheers
cyln is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
