Static mixture with surfaceNormalFixedValue inlet condition
Old   September 30, 2017, 10:53
Smile Static mixture with surfaceNormalFixedValue inlet condition
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hello Everyone,
I am new to openFoam, I am trying to solve static mixture problem. Geometry is having two inlets and one outlet, inlets are at different temperature. I am using buoyantBoussinesqSimpleFoam solver. my solution is failing after the first iteration only with the following error
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 0.580728
Specified mass inflow : 3.1262
Specified mass outflow : 0
Adjustable mass outflow : 8.70037e-152
From function adjustPhi(surfaceScalarField&, const volVectorField&,volScalarField&)
in file cfdTools/general/adjustPhi/adjustPhi.C at line 114.
FOAM exiting
Inlets are not aligned with the reference co-ordinate so I am using surfaceNormalFixedValue at the inlets, This condition is working well for simpleFoam.
Help me to resolve this issue
Regards,
Sunil
sunilpatil is offline   Reply With Quote
continuity error
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 10:20
How to specify a mixture of gases at inlet boundary condition? Matlab69 FLUENT 3 April 24, 2012 07:08
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
why the static pressure in inlet of fans was high jimmy Fidelity CFD 2 October 10, 2003 08:25
