Simple Foam
Old   September 30, 2017, 10:35
Default Simple Foam
ABHINAVMOHAN
abhinavmohan is on a distinguished road
I am getting this error
|  \\    /   O peration     | Version:  dev                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|* OpenFOAM for Windows 17.06 (v2)                                           *|
|* Built by CFD Support, www.cfdsupport.com (based on Symscape).             *|
Build  : dev-e2ccbbbb
Exec   : simpleFoam -parallel
Date   : Sep 30 2017
Time   : 14:27:39
Host   : "ABHINAV"
PID    : 7888
Case   : C:/OpenFOAM/17.06/Abhinav-dev/run/motorbike
nProcs : 6
Slaves :
5
"ABHINAV.8004"
"ABHINAV.4992"
"ABHINAV.7520"
"ABHINAV.4056"
"ABHINAV.4776"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: no convergence criteria found. Calculations will run for 100 steps.
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
kOmegaSSTCoeffs
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
No MRF models present
No finite volume options present
Starting time loop
streamLine streamLines:
    automatic track length specified through number of sub cycles : 5
nearWallFields near: Sampling 1 fields
job aborted:
[ranks] message
[0] process exited without calling finalize
[1-2] terminated
[3-4] process exited without calling finalize
[5] terminated
---- error analysis -----
[0,3-4] on ABHINAV
simpleFoam ended prematurely and may have crashed. exit code 3
any idea why this is happening?
abhinavmohan is offline   Reply With Quote
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
decomposePar is missing a library whk1992 OpenFOAM Pre-Processing 8 March 7, 2015 08:53
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
