Topology changes - problem when adding a layer for the second time
Old   September 30, 2017, 09:26
Default Topology changes - problem when adding a layer for the second time
Michael Frank
mike.franky is on a distinguished road
I am using the interDyMFoam with the rigidBodyMotion. I have adjusted the solver to allow topology changes as I need to add and remove layers next to a boundary.
Deleting layers works very well. When I add a layer for the first time, the addition also works. However, the second time around, after the addition of the layer, the solver crashes either with a segmentation fault on the GAMG solver for the pressure or because the cells moved to fast resulting in negative cell volumes.
I can see that the actual addition of the layer works fine. The problem is the subsequent motion of the grid. So if once the layer is added I ignore the motion then the simulation continues fine (albeit without any moving parts). As soon as the motion solver attempts to solve this new mesh, I start getting large pressures, time step continuity errors of the order of e+84 etc.
I am assuming that the fact that it fails during the second time is just because by then I have much greater velocities. Does anyone have any ideas as to why this may be?
mike.franky is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 03:23
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
