Physical problems on Vortex Induced Rotations of a cylinder
Old   September 30, 2017, 08:52
Default Physical problems on Vortex Induced Rotations of a cylinder
Dae-young(Dan)
fhjkfhjk is on a distinguished road
Hello, foamers.
I have been trying to simulate a 6-dof system with OpenFOAM 4.1.
The case is VIR of a cylinder, and its shape is square cylinder in 2D. (1m x 1m length and width)
I am using pimpleDyMFoam with Arbitrary Mesh Interfaces.
When I run the case, it numerically converged, however, the physical values are not matched with the reference paper.
Re number : 50, - in this regime, the rotations must be in equilibrium state after some time. But my simulation results kept going larger as resonance occured (the moment by a rigid body, and the force induced by vortex).
Re number : 70, as the case Re-50 goes into equilibrium state, this case must also be in that state, but it is fluctuating as it is a case of Re 80 or 90.
I have check the BCs and ICs, and dynamicMesh files so many times. but I still do not know what is the problem.
Any Idea of how stabilize the moment induced by flow?
if you need more information about my case, just let me know. I will show you the files I have made.
Thank you in advance.
By the way, the first graph is angular velocity of a cylinder when Re - 70, the second is Re - 50
fhjkfhjk is offline   Reply With Quote
6-dof, 6-dof rigid motion, dynamicmesh, vortex induced rotations
No Vortex shedding for diameter of 20mm in flow past cylinder shashanktiwari619 FLUENT 0 January 11, 2017 22:03
No Vortex shedding for flow past cylinder shashanktiwari619 FLUENT 7 December 28, 2016 10:35
vortex induced vibration from dynamic mesh natto Main CFD Forum 4 April 18, 2015 20:42
Vortex Induced Vibration - Comsol mahdimazloom COMSOL 0 July 14, 2014 03:52
Vortex induced vibration simulation using pimpleDyMFoam Amit-1911 OpenFOAM Post-Processing 1 April 16, 2014 02:16
