Can't get Uy component convergence - Couette flow
Old   September 28, 2017, 14:59
Default Can't get Uy component convergence - Couette flow
Lisandro Maders
Lisandro Maders is on a distinguished road
I am trying to make a tutorial case for students of a Couette flow between 2 parallel plates, with one of them at a constant velocity.
The domain is 2D:
Length (x direction) = 3 [mm]
Height (y direction) = 0.03 [mm] (yes, that small)
Boundary conditions I am using for velocity:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    movingWall
        type            fixedValue;
        value           uniform (14 0 0);
    fixedWalls
        //type            noSlip;
        type            fixedValue;
        value           uniform (0 0 0);
    inlet
        type            zeroGradient;
        //type            cyclic;
    outlet
        type            zeroGradient;
        //type            cyclic;
    frontAndBack
        type            empty;
and for pressure:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    movingWall
        type            zeroGradient;
    fixedWalls
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           uniform 0;
    outlet
        type            fixedValue;
        value           uniform 0;
    frontAndBack
        type            empty;
The case is laminar, 2D, steady-state.
My mesh files and case setup files are attached.
The problem is that I am having ok results for Ux, but weird behavior for Uy component. The convergence for Uy do not get smaller than 0.01, even though the Ux convergence is around e-16 !!
Looking at the results (see Figure attached), I have a weird field of Uy. However, all the values are close to e-12 (pretty much zero). Why is it happening?
Best regards,
Lisandro
File Type: zip constant.zip (912 Bytes, 0 views)
Lisandro Maders is offline   Reply With Quote
Old   September 28, 2017, 15:01
Default Showing the OK results for Ux components
Lisandro Maders
Just attaching the Ux components results..
Old   September 28, 2017, 16:09
Default Residuals calculation
Lisandro Maders
Actually, I think there is a problem in the way I am interpreting the residuals in OpenFOAM. I run same case right now in Fluent, it converges in 10 seconds, and if I scale the Uy results to see between -1e-12 and 1e-12 I also see some numerical errors like the ones in the Figure attached.
I know this is actually zero for the computer, however, why isn't the Uy residuals converging? Why is it considering such small values in residuals calculation?
Am I missing something here?
Regards,
Lisandro
convergence, couette flow, uy component
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Solar heater flow rate, natural convection convergence Arttis FLUENT 0 March 23, 2017 13:24
Flow through manifold: convergence issues malleYay FLUENT 0 October 24, 2016 04:39
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 04:00
Force can not converge colopolo CFX 13 October 4, 2011 23:03
