Evaluating view factors in OpenFoam 5.0
Old   September 26, 2017, 18:41
Default Evaluating view factors in OpenFoam 5.0
Franco
fracasce is on a distinguished road
Dear Foamers,
I'm having troubles in solving a conjugate heat transfer problem with thermal radiation. The problem I'm trying to solve is very similar to the tutorial multiRegionHeaterRadiation (a problem with conduction, convection and radiation). In order to solve this problem, the view factors need to be evaluated according to the info listed in the viewFactorsDict file (obviously, for the fluid region). However, when I run the viewFactorsGen command, OF crashes, and the output of the log.viewFactorsGen is the following:
Create time
Create mesh Air for time = 0
Total number of coarse faces: 0
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  ? at ??:?
#4  ? at ??:?
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6  ? at ??:?
Segmentation fault (core dumped)
Do you have any idea about how to fix this error? I tried to change the number of the nFacesInCoarsestLevel, but it didn't help. It seems that an answer has been provided in this post, but it doesn't seem to me that this answer is well suited for my problem.
Can anyone help me? Thanks!
Franco
fracasce is offline   Reply With Quote
Old   September 27, 2017, 13:34
Franco
Dear Foamers,
Apparently, the problem I had was caused by the fact that tha variable Qr in OF4.1 has been changed to qr. Changing the names of the variables qr and qro has fixed the problem.
Franco
view factors, viewfactorsgen
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
View factors calculation outside Fluent Sambou FLUENT 1 January 21, 2006 14:48
Thermal Radiation View Factors and NEVADA software Christos Chasapopoulos Main CFD Forum 0 May 11, 2005 10:28
Help: view factors file Giovanni Siemens 2 June 6, 2003 03:50
