September 26, 2017, 08:53 |
Segmentation fault (core dumped)
Patrick
Rep Power: 10 |
I'm using OpenFoam-3.0.1 for simulations and it was working fine until I upgraded from Ubuntu 14 to 16.04 LTS. I got the following error when trying to run a simulation: error while loading shared libraries: libmpi.so.1: cannot open shared object file: No such file or directory
I have tried the following suggested steps to get OpenFoam working again:- #Go into OpenFOAM's main source folder cd $WM_PROJECT_DIR #Change how the flex version is checked find src applications -name "*.L" -type f | xargs sed -i -e 's=\(YY\_FLEX\_SUBMINOR\_VERSION\)=YY_FLEX_MINOR_V ERSION < 6 \&\& \1=' file:///home/hp/OpenFOAM/OpenFOAM-3.0.1/logs.tar.gz This seems to have solve the problem but gave rise to a new problem: Segmentation fault (core dumped) I have tried several suggested steps to resolve this new problem to no avail. These include: sudo apt-get clean sudo apt-get check sudo apt-get autoremove sudo apt-get update sudo apt-get upgrade I also run Allwmake (Attached) to search for clues but got more confused The first error line reads /home/hp/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/mesh/manipulation/createBaffles In file included from lnInclude/CGALTriangulation3Ddefs.H:41:0, from DelaunayMeshTools/DelaunayMeshTools.H:45, from DelaunayMeshTools/DelaunayMeshTools.C:26: lnInclude/CGALTriangulation3DKernel.H:36:43: fatal error: CGAL/Delaunay_triangulation_3.h: No such file or directory compilation terminated. /home/hp/OpenFOAM/OpenFOAM-3.0.1/wmake/rules/General/transform:8: recipe for target '/home/hp/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/DelaunayMeshTools/DelaunayMeshTools.o' failed make[2]: *** [/home/hp/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/DelaunayMeshTools/DelaunayMeshTools.o] Error 1 I would appreciate any help towards resolve this issue. I will remove and reinstall Openfoam as a last resort. Thanks Patrick |
September 28, 2017, 07:14 |
Tobias Holzmann
Rep Power: 51 |
Hi Patrick,
if you build FOAM with older libraries, it is clear that during the update of ubuntu, the old libraries are replaced by new ones (see flex etc.). However, your compilation is based on the old libraries so this will not work anyway. You have to recompile your code with the usage of the new libraries. Sometimes it happens that libraries are also renamed and you have to provide a symbolic link. However, I would clean everything and recompile it. In addition, switch to the latest FOAM version to have bug-fixes included. If you are working in two-phase flows I only can recommend it.
Keep foaming, Tobias Holzmann |
September 29, 2017, 04:04 |
#3 | |
Patrick
Rep Power: 10 |
Thanks for responding. I will follow you recommendation to swtich to the latest OF version. I hope for a smooth switch. Thanks |
[OpenFOAM] paraview parafoam segmentation fault (core dumped) | RicardoLB | ParaView | 3 | April 28, 2020 20:07 |
[Other] fe40 surfaceConvert Segmentation Fault (core dumped) | bhakar.raju98 | OpenFOAM Meshing & Mesh Conversion | 2 | June 16, 2019 11:04 |
Segmentation fault (core dumped) | Sugajen | OpenFOAM Running, Solving & CFD | 1 | August 2, 2017 12:06 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
Segmentation fault (core dumped) when changing pressure BC | jptorol | OpenFOAM Running, Solving & CFD | 0 | September 25, 2013 18:05 |
