September 26, 2017, 09:26 |
Problem with simulations in parallel
Alejandro Valeije
Rep Power: 12 |
Hi there!
I'm having this problem. In previous versions of OpenFOAM, i was able to run run several simulations in parallel with all cores at full speed. But in OF4.1, if I have, let's say, a simulation running in 2 proccessors, and I run another, similar to the first one, with the same amount of processors, the power divides, and now I have 2 simulations in parallel running with 2 proccessors each, but only at 50% each proccessor. Anyone has any idea why this is happing, or how can it be solved? I hope the problem is clearly explained. Cheers, Alex |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 20:12 |
problem for parallel processing | minaret | OpenFOAM Running, Solving & CFD | 14 | January 20, 2015 00:41 |
problem about running parallel on cluster | killsecond | OpenFOAM Running, Solving & CFD | 3 | July 23, 2014 22:13 |
problem in the CFX12.1 parallel computation | BalanceChen | ANSYS | 2 | July 7, 2011 11:26 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 16:41 |
