September 26, 2017, 09:07 |
unknown FOAM FATAL IO ERROR: what means?
giovanni
Rep Power: 9 |
hi guys i'm new in cfd simulations.. i'm going to simulate a port flow but when i run the solver i got this error. i'm trying to understand this problem but i didnt' manage in it.
could anyone help me ?? n -np 4 simpleFoam -parallel /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : simpleFoam -parallel Date : Sep 26 2017 Time : 13:05:21 Host : "gio-HP-EliteBook-8460p" PID : 3916 Case : /home/gio/OpenFOAM/gio-4.1/run/cdfprog2609/progetto3.1 nProcs : 4 Slaves : 3 ( "gio-HP-EliteBook-8460p.3917" "gio-HP-EliteBook-8460p.3918" "gio-HP-EliteBook-8460p.3919" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerann -np 4 simpleFoam -parallel /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : simpleFoam -parallel Date : Sep 26 2017 Time : 13:05:21 Host : "gio-HP-EliteBook-8460p" PID : 3916 Case : /home/gio/OpenFOAM/gio-4.1/run/cdfprog2609/progetto3.1 nProcs : 4 Slaves : 3 ( "gio-HP-EliteBook-8460p.3917" "gio-HP-EliteBook-8460p.3918" "gio-HP-EliteBook-8460p.3919" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi [0] [0] [0] --> FOAM FATAL IO ERROR: [0] cannot open file [0] [0] file: /home/gio/OpenFOAM/gio-4.1/run/cdfprog2609/progetto3.1/processor0/constant/transportProperties at line 0. [0] [0] From function regIOobject::readStream() [0] in file db/regIOobject/regIOobjectRead.C at line 86. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. ce 0.001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi [0] [0] [0] --> FOAM FATAL IO ERROR: [0] cannot open file [0] [0] file: /home/gio/OpenFOAM/gio-4.1/run/cdfprog2609/progetto3.1/processor0/constant/transportProperties at line 0. [0] [0] From function regIOobject::readStream() [0] in file db/regIOobject/regIOobjectRead.C at line 86. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. |
September 26, 2017, 09:32 |
Alejandro Valeije
Rep Power: 12 |
Hi Gio,
Have you checked if you have a file called "transportProperties" in your "constant" folder?? If so, it is readable? (I mean, can u open it without problems) Alex |
September 26, 2017, 11:55 |
giovanni
Rep Power: 9 |
hi alex. i've made a mistake. the solver to use is not sympleFoam but rhoSimpleFoam.
anyway i cancel this thread and open a new one since i still have errors. thanks |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 08:49 |
Derivative of velocity and mean velocity | hiuluom | OpenFOAM Post-Processing | 1 | May 30, 2015 00:42 |
Thermal Comfort Simulation in STAR CCM+ | anupmu | STAR-CCM+ | 1 | February 27, 2013 15:25 |
