September 24, 2017, 13:28 |
Generating appropriate blockMeshDict File
Jack Hanson
Rep Power: 9 |
I'm trying to run blockmesh but I keep getting an error. the below is my error message. I don't know what i'm doing wrong. If could get another pair of eyes to look at this I would greatly appreciate it.
Actual Error Message: "FOAM FATAL IO ERROR: Block hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1(1) 1(1) 1(1)) is inside-out file: /home/jackhansonjr/OpenFOAM/openfoam5/tutorials/incompressible/pimpleDyMFoam/Torpedo/system/blockMeshDict.blocks at line 34. " blockmeshdict file: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.305; vertices ( (-10 -1.84 -1.84) // 0 - Left Bottom Back (-10 -1.84 1.84) // 1 - Left Bottom Front (-10 1.84 1.84) // 2 - Left Top Front (-10 1.84 -1.84) // 3 - Left Top Back (10 -1.84 -1.84) // 4 - Right Bottom Back (10 -1.84 1.84) // 5 - Right Bottom Front (10 1.84 1.84) // 6 - Right Top Front (10 1.84 -1.84) // 7 - Right Top Back ); blocks ( hex (0 1 2 3 4 5 6 7) (10 10 10) simpleGrading (1 1 1) ); edges ( ); boundary ( topAndBottom { type patch; faces ( (3 7 6 2) (1 5 4 0) ); } inlet { type patch; faces ( (0 4 7 3) ); } outlet { type patch; faces ( (2 6 5 1) ); } symFront { type symmetryPlane; faces ( (4 5 6 7) ); } symBack { type symmetryPlane; faces ( (0 3 2 1) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
September 24, 2017, 17:07 |
Denys Wickens
Rep Power: 9 |
Look up blockMesh in the openFoam instructions or a Wiki, and sketch and number your vertices. You've gone clockwise when blockMesh is expecting counter-clockwise or vice-versa, or not put in the lowest face as the first four vertices. Thus you think you're fine but blockMesh thinks your shape is inside-out.
After about 5 years of using blockMesh this is still my commonest error. |
beginner, blockmeshdict block mesh |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 11:03 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
