September 21, 2017, 09:02 |
Cyclone separator using multiphaseEulerFoam
CFDfreak
Rep Power: 9 |
Hello everyone
I have been modelling a cyclone separator with a tangential inlet and two outlets, one at top and other at bottom. I am using openFoam 4.1. I am trying with multiphaseEulerFoam since the model contains four phases, the continuous phase is air and dispersed phases are oil, water and sand. The mesh contains 0.24million hex dominated cells, created using snappyHexMesh. Turbulence model I am using is realizableKE. Right now I have initiated flow only using air and oil. This is not giving proper cyclone profile. The velocity at inlet is 0.9 m/s. The courant number mean is 0.002-0.0002. Also sometimes the the minimum volume fraction is becoming negative for water. Kindly someone guide me. Also I am tried attaching my boundary condition and fvsolution case file . It is showing some error(file invalid) Thank you. Last edited by nandhakumar; September 26, 2017 at 02:25. |
Ideas about Gas - Solid Cyclone Separator Simulations | ardismo | Main CFD Forum | 0 | January 11, 2016 10:46 |
Particle separation in an axial cyclone | Cloudseeker | CFX | 3 | August 19, 2014 20:13 |
Steam-Water Vertical Cyclone Separator | Munggang | FLUENT | 3 | April 29, 2014 13:38 |
requiring solution for heat transfer from gas to solid particle in cyclone | suvai79 | FLUENT | 0 | September 1, 2012 05:48 |
Modelling Industrial cyclone behaviour | Günther Hasse | Main CFD Forum | 3 | October 12, 1999 19:34 |
