About the totalPressure BC
Old   September 21, 2017, 06:02
Default About the totalPressure BC
fmerk is on a distinguished road
Hello foamers,
I'm working on a simulation where the velocity upstream at the inlet is unknown. To solve the incompressible flow, I'm working with interFoam using Openfoam version v1612+. I'm applying the totalPressure boundary condition. It's defined as:
p_p = p_0 - 0.5*u^2
where I insert rho*g* z coordinate of flow height at inlet for p_0.
Now my question is:
- Openfoam doesn't complain about my numerical setup, yet from a physical point of view, using the hydrostatic pressure rho*g*z for p_0 in the totalPressure boundary (at the inlet) doesn't make sense, does it? I'd say the pressure is underestimated.
- If I impose the totalPressure BC at the inlet patch, is the p_rgh field for this patch then representing the total pressure (as defined by e.g. Bernoulli)? Usually, p_rgh is defined as p_rgh = p - rho*g*h(z), so not necessarily the total pressure.
Displaying the results in paraview implies another complication for me:
the mean p_rgh(inlet patch value) is 19033 for one particular test case. If I add the dynamic pressure (0.5*rho*u^2), I end up with 21091.5 which I initially set p_0 for the totalPressure BC (as hydrostatic pressure with 9810*2.15m). So, is the p_rgh field representing the hydrostatic share of the pressure distribution?
- The resulting velocity, which then determines the dynamic pressure, is also mysteriously arising for me. Where does the U come from? I'm using a pressureInletOutletVelocity boundary condition for my U field. There, the velocity is calculated via the flux phi.
How are the totalPressure BC and the velocity connected? If someone could illuminate this context to me, I'd really be happy. If i missed some obvious explanation somewhere in the forum or in one of the comprehensive theses by jasak or ruschke, just point it out!
kind regards
fmerk is offline   Reply With Quote
Old   September 25, 2017, 18:53
M. C.
student666 is on a distinguished road
for a solver like simpleFoam, when you set a totalPressure bc on a patch (outlet) you should set a velocity bc as well.
The other patch (inlet) should be set with a fixed pressure and a outletInlet bc that could be:
        type            outletInlet;
        phi             phi;
        outletValue     uniform 0;
        value           uniform 0;
This closes your problem.
The solver uses the velocity to calculate p(static) field at the outlet and with the p fixed at inlet it can solves for the velocity at the inlet and satisfy the Bernoulli equation.
(truly speaking i don't think it does this way, but by hand calculation it is what I do)
I think that interFoam does the same, but it's supposed to take a further step as for g field that is a "sort of source" (body forces) for the p field as for different density of the different phases....I think that phisically speaking it is what it does...and it should behave like simpleFoam + further corrections...
You can test totalPRessure bc and better understand its behaviour by testing a simple channel case with an easier solver as icoFOAM.
Regards.
student666 is offline   Reply With Quote
totalPressure (why flux direction dependend) Tobi OpenFOAM Running, Solving & CFD 3 October 17, 2019 23:27
Need info about totalPressure boundary condition sahmed OpenFOAM Running, Solving & CFD 4 December 4, 2018 22:23
totalPressure boundary :Performance Curve (constant RPM) nash OpenFOAM Running, Solving & CFD 0 September 6, 2013 12:34
Totalpressure Ansys Leuchte CFX 2 April 9, 2013 19:56
BC settings to expand pressure on atmosphere - simpleFoam / totalPressure sErik OpenFOAM Running, Solving & CFD 1 June 15, 2011 03:49
