Non-physical pressure at cyclicAMI patches
Old   September 20, 2017, 18:35
Default Non-physical pressure at cyclicAMI patches
MNoCeZ is on a distinguished road
before posting this thread i searched for solutions in this forum and the web general, but without success.
Before describing the problem same informations about my investigated case.
Case
the case is a jet stream with a cross-section expansion to ensure detached eddies. At the inlet it was used a farfield with a fixed pressure and a velocity set to zero. At the outlet it was used an averaged fixed pressure. The velocity gets calculated by fluxCorrectedVelocity.
Mesh
the mesh was created with numeca's autogrid and then also converted with autogrid to an openfoam mesh.
Solver
the solver is rhoSimpleFoam. Convergence plot:
Problem
The Mesh has non-conformal Blocks which i set to cyclicAMI in the boundary file. For example:
cyclicAMI_patch_1
        nFaces 1200;
        startFace 22194240;
        type cyclicAMI;
        inGroups 1(cyclicAMI);
        matchTolerance 0.0001;
        neighbourPatch cyclicAMI_patch_2;
        transform noOrdering;
The initial solution of the
cyclicAMI_patch_1 for ervery needed quantitie was set to
cyclicAMI_patch_1
     type            cyclicAMI;
     value           $internalField;
The problem is, that the pressure and the velocity has non-physical values at the cyclicAMI patches.
pressure:
velocity:
Is there an option to avoid these non-physical values at the cyclicAMI patches?
MNoCeZ is offline   Reply With Quote
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
CyclicAMI issues vabishek OpenFOAM Pre-Processing 1 December 6, 2015 17:37
problem with cyclicAMI and wall distance Maff OpenFOAM Bugs 5 August 14, 2014 15:41
Regarding periodic BC in ICEM generated grid Tarak OpenFOAM 32 April 30, 2013 15:46
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
