September 18, 2017, 09:43 |
SimpleFoam high order schemes
Vedamt Chittlangia
Rep Power: 9 |
I am simulating flow around vane cascade. I have good mesh quality with checkMesh reporting OK for all checks and the maximum non-orthogonality at 41. I was able to get converged solution with first order schemes (bounded Gauss upwind) but when i switched to higher order schemes, my solution diverged with 'Nan'. Solver: simpleFoam RASModel: LaunderSharmaKE (or kOmegaSST) Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(U) leastSquares; grad(T) leastSquares; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss linearUpwind default; div(phi,epsilon) bounded Gauss upwind; div(phi,R) bounded Gauss linearUpwind default; div(phi,nuTilda) bounded Gauss linearUpwind default; div((nuEff*dev(T(grad(U))))) Gauss linear; div(phi,T) bounded Gauss linearUpwind grad(T); } laplacianSchemes { default Gauss linear corrected; laplacian(1,Phi) Gauss linear corrected;// limited 0.5; laplacian(nuEff,U) Gauss linear corrected;// limited 0.5; laplacian((1|A(U)),p) Gauss linear corrected;// limited 0.5; laplacian(DkEff,k) Gauss linear corrected;// limited 0.5; laplacian(DepsilonEff,epsilon) Gauss linear corrected;// limited 0.5; laplacian(DREff,R) Gauss linear corrected;// limited 0.5; laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;// limited 0.5; laplacian(kappaEff,T) Gauss linear corrected;// limited 0.5; } interpolationSchemes { default linear; interpolate(U) linear; interpolate(T) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; Phi; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { Phi { solver GAMG; smoother DIC;//GaussSeidel; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; tolerance 1e-6; relTol 0.01; } p { solver PCG; preconditioner DIC; tolerance 1e-12; relTol 0.0001; //maxIter 200; /* solver GAMG; tolerance 1e-08; relTol 0.001; minIter 5; //added later maxIter 200; //added later smoother GaussSeidel; // DIC; //DICGaussSeidel; //FDIC; nPreSweeps 1; nPostSweeps 3; nFinestSweeps 3; cacheAgglomeration true; nCellsInCoarsestLevel 100; agglomerator faceAreaPair; mergeLevels 1; */ } /* pFinal { $p; relTol 0; } */ "(U|T|k|epsilon)" { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0.1; /* solver smoothSolver; smoother GaussSeidel; tolerance 1e-3; relTol 0; */ } "(R|nuTilda)" { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0.1; /* solver smoothSolver; smoother GaussSeidel; tolerance 1e-3; relTol 0; */ } } SIMPLE { nNonOrthogonalCorrectors 0; residualControl { p 1e-8; U 1e-8; k 1e-8; epsilon 1e-8; T 1e-8; } } potentialFlow { nNonOrthogonalCorrectors 10; } relaxationFactors { fields { p 0.1; } equations { default 0.3; U 0.5; k 0.5; epsilon 0.5; R 0.4; T 0.6; nuTilda 0.4; } } // ************************************************************************* // Thanks |
September 18, 2017, 23:45 |
Ping Chang
Rep Power: 10 |
Could you please post your log file? |
September 19, 2017, 11:38 |
log files
Vedamt Chittlangia
Rep Power: 9 |
Hello Ping,
I had tried several fvSchemes options for divergence before settling on the ones that I mentioned. My log files are for kwSST model where omega is bounded Gauss upwind and all other are same. Link to log files Thanks |
accuracy, fvschemes, komegasst, simplefoam convergence |
Choice of numerical schemes for high accuracy in vorticity | D.B | OpenFOAM Running, Solving & CFD | 1 | February 5, 2018 10:44 |
simpleFoam: switch so second order fvSchemes | okroud | OpenFOAM Running, Solving & CFD | 11 | September 11, 2013 12:52 |
For second or first order accurate schemes, to what extent, the results are valid? | tfuwa | OpenFOAM Running, Solving & CFD | 1 | July 7, 2013 17:47 |
2nd order boundary conditions for 2nd order discretization? | quarkz | Main CFD Forum | 30 | December 26, 2011 07:12 |
CFL condition for higher order schemes | Shyam | Main CFD Forum | 2 | February 14, 2008 14:24 |
