rhoSimpleFoam pressure P is not satisfy perfect gas state equation at inlet patch
Old   September 18, 2017, 07:40
Default rhoSimpleFoam pressure P is not satisfy perfect gas state equation at inlet patch
ff
fxzf is on a distinguished road
Hi Foamers,
In my simulation, I have a jet flow which is similar with Aircraft engine outlet. So at this inlet patch, I set mass flow rate and totaltemperature boundary condtion.
Now the problem is after simulation, I got the following solutions at this flow inlet patch
T (static temperature) = 803 (this is satisfy what I expected)
rho = 0.4633 (this is satisfy what I expected)
U = 156.8 (this is satisfy what I expected)
p = 1.156e5
The problem is pressure p. If we perform a hand calculation using perfect gas state equation, p = rho*R*T = 0.4633 * 287.1 * 803 = 106809.78429 = 1.068e5 which is also what I expected value. However, the p I got from solution is 1.156e5. This is not what I expected and not even satisfy perfect gas state equation.
Doese anyone has any idea what is wrong here?
Thanks a lot.
fxzf is offline   Reply With Quote
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 7 September 18, 2024 06:52
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
