#1 | ||||||
Rep Power: 9 ![]() |
Hello FOAMers!
I am trying to simulate something like an explosion in an open field. It's a 2D simulation with the explosive on the ground. The explosive is simulated as a "balloon" with high pressure. Although, this is the error I get: Quote:
epsilon Quote:
I would really appreciate if you could help me! |
dengli
Rep Power: 11 ![]() |
[QUOTE=Calmly;664350]Hello FOAMers!
Hi, Calmly Have you solved your problem? I'm not sure where the exactly the problem are, but with this high compressible problem, I would choose the upwind or the limitedLinear in the grad schemes. |
Taher Chegini
Rep Power: 12 ![]() |
The boundary conditions doesn't seem right to me. On the sides I would suggest to use fixedFluxPressure for p and inletOutlet or slip for U, assuming that sides are far enough from the region of interest.
pressureInletOutletVelocity is used when pressure is prescribed in the boundary. Also, I suggest to use upwind for schemes at first to make sure model works. Once you get reasonable results you can use higher order schemes. |
Heat Transfert, mixing problem | Wazdq | CFX | 8 | November 7, 2016 05:44 |
DPM converging Problem | Markus Alzon | FLUENT | 6 | April 7, 2016 11:41 |
DPM Converging Problem | Aimara | FLUENT | 5 | June 11, 2007 09:45 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
