chtMultiRegionSimpleFoam nonlinear heat conduction wrong temperature prediction
Old   September 14, 2017, 04:10
Default chtMultiRegionSimpleFoam nonlinear heat conduction wrong temperature prediction
bbjolle is on a distinguished road
Hello everybody,
as a preliminary work I am performing a validation of chtMultiRegionSimpleFoam for a simple nonlinear heat conduction problem. M. Danish et. al. developed an analytical solution for the 1D steady state heat conduction in a rod with linear varying heat conductivity.
http://www.iaeng.org/publication/WCE...p2550-2555.pdf
I face a problem that I need much more cells with the chtMRSF solver to predict the temperature profile and the wallHeatFlux as can be seen in this figure.
With ANSYS Fluent I am able to predict the wallHeatFlux quite good with even three cells. To get comparable results with chtMRSF I need 160 cells.
Are there any improvements possible in my settings?
I am using OF 5.0 and the case is based on the multiRegionHeaterRadiation tutorial. BottomAir is only a dummy, with no influence on the solid heater region. I have implemented the linear varying heat conductivity like this
thermoType
    transport       polynomial;
    thermo          hPolynomial;
mixture
    transport
        kappaCoeffs<8>     (-58.8 0.2 0 0 0 0 0 0);
    thermodynamics
        Hf      0;
        Sf      0;
        CpCoeffs<8>     ( 1 0 0 0 0 0 0 0 );
nonLinearHeatConduction.zip
regards
Björn
bbjolle is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Particle Tracking - Heat transfer and temperature mxodio CFX 8 August 7, 2015 13:43
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
convergenceof natural convection prob. in cfx cpkewat CFX 15 January 31, 2014 07:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
