Diverging runs with 3d double cone
Old   September 13, 2017, 22:48
Default Diverging runs with 3d double cone
TWB
quarkz is on a distinguished road
I'm simulating a 3d double cone in high speed flow using rhoCentralFoam. Initially I used a coarse grid (0.4M cells) and although the speed is slow, it runs fine with 4 procs. Using more procs doesn't seem to help much.
I then changed to a finer grid with 4M cells. It diverges after a very short while - about 1 min. I tried to reduce the initial time step to as low as 1e-12, with a low CFL of 0.1 but it still diverges.
So I'm wondering what should I change now?
For BC, most faces are more or less standard (fixed value inlet, symmetry).
For the outlet, I'm using inletOutlet and waveTransmissive for U and p. I wonder if I need to change.
For the fvSolution, I'm using:
solvers
"(rho|rhoU|rhoE)"
solver diagonal;
U
/*solver smoothSolver;
smoother GaussSeidel;
nSweeps 2;
tolerance 1e-9;
relTol 0.01;*/
solver PCG;
preconditioner FDIC;
tolerance 1e-09;
relTol 0.01;
while for the fvSchemes, I'm using:
fluxScheme Kurganov;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(tauMC) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;//limitedLinear 1.0; //
reconstruct(rho) upwind;//vanLeer; MUSCL; Gamma
reconstruct(U) upwind;//vanLeerV; MUSCL; GammaV
reconstruct(T) upwind;//vanLeer; MUSCL; Gamma
snGradSchemes
default corrected;
Being a new user to OpenFOAM, I hope someone can give some advice.
Thanks!
quarkz is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 04:34
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 07:09
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
