September 13, 2017, 21:17 |
Error running RAS kEpsilon
TWB
Rep Power: 19 |
I am trying to convert my original laminar 3D double cone case to a RAS case, with the k Epsilon model. The laminar case can run but it diverges after a short while. FYI, I'm using rhoCentralFoam with compressible high speed flow. I tried to view some youtube tutorials on implementing a RAS case. However I got this error which I can't solve. So my simulation can't start. Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 6960 average: 6960 bounding epsilon, min: 0 max: 183 average: 183 kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; } No finite volume options present --> FOAM FATAL ERROR: Different dimensions for = dimensions : [0 2 -1 0 0 0 0] = [1 -1 -1 0 0 0 0] From function bool Foam::dimensionSet:perator=(const Foam::dimensionSet&) const in file dimensionSet/dimensionSet.C at line 171. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::dimensionSet:perator=(Foam::dimensionSet const&) const at ??:? #3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>:perator=(Foam::tmp<Foam::Geometri cField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/tsltaywb/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam" #4 Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foa m::CompressibleTurbulenceModel<Foam::fluidThermo> > >::correctNut() at ??:? #5 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Fo am::ThermalDiffusivity<Foam::CompressibleTurbulenc eModel<Foam::fluidThermo> > > >::correctNut() at ??:? #6 ? in "/home/tsltaywb/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam" #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? in "/home/tsltaywb/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam" Aborted (core dumped) So can someone tell me where the error can't from? So that I can look at the right place. Thanks! |
December 31, 2018, 03:10 |
Bidesh Sengupta
Rep Power: 8 |
Hi Can any one please help me to overcome it.. Than you very much.
Overall domain bounding box (0 0 0) (1 0.4 0.1) p { margin-bottom: 0.1in; line-height: 115%; } Error: Time = 10 GAMG: Solving for Ux, Initial residual = 0.424802, Final residual = 0.017996, No Iterations 1 GAMG: Solving for Uy, Initial residual = 0.332272, Final residual = 0.0140346, No Iterations 1 GAMG: Solving for Uz, Initial residual = 0.559406, Final residual = 0.0285128, No Iterations 1 GAMG: Solving for e, Initial residual = 0.574963, Final residual = 0.0496275, No Iterations 1 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? #4 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #5 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/rhoSimpleFoam" Floating point exception (core dumped) /*---------------------------------------------------------------------------------*/ Model: rhoSimpleFoam /*---------------------------------------------------------------------------------*/ Boundary Condition: 1. Pressure frontandback { type symmetry; } inlet { type zeroGradient; //type mixed; //refValue uniform 100000; //refGradient uniform 0; //valueFraction uniform 0.3; } outlet { type fixedValue; value uniform 100000; } wall { type zeroGradient; } 2. Velocity frontandback { type symmetry; } inlet { type fixedValue; value uniform (5 0 0); rhoInlet 1.5; } outlet { type zeroGradient; } wall { type noSlip; } 3. Temperature frontandback { type symmetry; } inlet { type fixedValue; value uniform 300; } outlet { type zeroGradient; } wall { type zeroGradient; } 4. k frontandback { type symmetry; } inlet { type turbulentMixingLengthDissipationRateInlet; mixingLength 0.14; value uniform 0.1; } outlet { type inletOutlet; inletValue uniform 1; value uniform 1; } wall { type kqRWallFunction; value uniform 1; } 5. epsilon frontandback { type symmetry; } inlet { type turbulentMixingLengthDissipationRateInlet; mixingLength 0.14; value uniform 0.006; } outlet { type inletOutlet; inletValue uniform 0.006; value uniform 0.006; } wall { type epsilonWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0.006; } 6. nut frontandback { type symmetry; } inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } wall { type nutkWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value uniform 0; } 7. alphat frontandback { type symmetry; } inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } wall { type compressible::alphatWallFunction; Prt 0.85; value uniform 0; } /*------------------------------------------------------------------------------*/ fvSolution ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(phi,e) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phid,p) Gauss upwind; div(phi,Ekp) bounded Gauss upwind; div((phi|interpolate(rho)),p) Gauss upwind; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } /*----------------------------------------------------------------------*/ fvSolution solvers { p { solver GAMG; tolerance 1e-08; relTol 0.1; smoother GaussSeidel; nCellsInCoarsestLevel 20; } "(U|e|k|epsilon)" { solver GAMG; tolerance 1e-08; relTol 0.1; smoother GaussSeidel; nCellsInCoarsestLevel 20; } } SIMPLE { nNonOrthogonalCorrectors 0; rhoMin 0.1; rhoMax 1.5; //pMaxFactor 2; //pMinFactor 0.1; transonic yes; consistent yes; residualControl { p 1e-3; U 1e-4; e 1e-3; // possibly check turbulence fields "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p 0.3; rho 0.7; } equations { p 0.7; U 0.7; e 0.7; k 0.7; epsilon 0.7; } } p { margin-bottom: 0.1in; line-height: 115%; } |
Error in LRR (RAS) model in OpenFOAM v4.1 | Inquisitor101 | OpenFOAM | 4 | November 29, 2023 14:11 |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
rhoSimpleFoam searches for RAS model | hamsteri15 | OpenFOAM Running, Solving & CFD | 3 | February 10, 2016 11:00 |
Explanation for terms like RAS turbulence, kEpsilon,... | tH3f0rC3 | OpenFOAM Pre-Processing | 2 | March 16, 2011 09:16 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
