Wrong Boundary Conditions (maximum number of iterations) in compressibleInterDyMFoam
Old   September 11, 2017, 08:05
Default Wrong Boundary Conditions (maximum number of iterations) in compressibleInterDyMFoam
Oliver K
silencebreak is on a distinguished road
Hey there,
I've got a problem with running the case in compressible Mode. The case is running without any errors in incompressible, so I don't think the error could be in the mesh therefore only the BCs of the compressible solver could be chosen wrong.
The case:
The case consists an upper reservoir (kaverneWall, atmosphere) a pipe system with a valve (ACMI-patches, AMI, slide_interface) at the bottom which is closing. The water is set at a level in the reservoir which is flooding down the pipe. The case is going to be calculated in turbulence mode but for the start i tried the BCs in laminar mode to work.
The problem:
The pressure is rising and it occurs an error regarding the maximum limitation of iterations are exceeded.
The error looks like:
max(U) 799.31
min(p_rgh) -640853
PIMPLE: iteration 2
MULES: Solving for alpha.water
Liquid phase volume fraction = 0.148083  Min(alpha.water) = -8.56923  Min(alpha.air) = -11.9184
Liquid phase volume fraction = 0.148095  Min(alpha.water) = -1851.18  Min(alpha.air) = -50816.1
Liquid phase volume fraction = 0.255911  Min(alpha.water) = -7.80007e+06  Min(alpha.air) = -1.29547e+09
Liquid phase volume fraction = 46.493  Min(alpha.water) = -9.70012e+11  Min(alpha.air) = -6.11008e+11
Liquid phase volume fraction = -3.36312e+21  Min(alpha.water) = -4.89659e+31  Min(alpha.air) = -3.17104e+24
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for T, Initial residual = 1, Final residual = 0.331259, No Iterations 1001
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
    From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
    in file /projects2/OF_bin/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/projects2/OF_bin/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
alpha.water
atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    kaverneWall
        type            zeroGradient;
    outlet
        type            zeroGradient;
    pipeWall
        type            zeroGradient;
    AMI
        type            zeroGradient;
    slide_interface
        type            zeroGradient;
    ACMI1_couple
        type            cyclicACMI;
        value           uniform 0;
    ACMI1_blockage
        type            zeroGradient;
    ACMI2_couple
        type            cyclicACMI;
        value           uniform 0;
    ACMI2_blockage
        type             zeroGradient;
p
internalField   uniform 101325;
boundaryField
    atmosphere
        type            calculated;
        value           $internalField;
    kaverneWall
        type            calculated;
        //type            zeroGradient;
    outlet
        type            calculated;//was fixedValue
    pipeWall
        type            calculated;
    AMI
        type            calculated;
    slide_interface
        type            calculated;
    ACMI1_couple
        type            cyclicACMI;
    ACMI1_blockage
        type            calculated;
    ACMI2_couple
        type            cyclicACMI;
    ACMI2_blockage
        type            calculated;
p_rgh
atmosphere
    { type            totalPressure;
        rho             rho;
        psi             none;
        gamma           1;
        p0              uniform 0;
        value           uniform 101325;
    kaverneWall
        type            fixedFluxPressure;//was zeroGradient latest fixedFluxPressure
        gradient        uniform 0;
outlet
        type            zeroGradient;
        //type            fixedValue;
        //value           $internalField;
    pipeWall
        gradient        uniform 0;
    AMI
        gradient        uniform 0;
    slide_interface
        gradient        uniform 0;
    ACMI1_couple
        type            cyclicACMI;
        value           $internalField;//was uniform 0
    ACMI1_blockage
        type            fixedValue;
        //type            zeroGradient;//was calculated
        //value           uniform 0;
    ACMI2_couple
        type            cyclicACMI;
ACMI2_blockage
        type            fixedFluxPressure;//was calculated
        gradient        uniform 0;
        //value           uniform 0;
T:
internalField   uniform 293.15;
boundaryField
    atmosphere
        type            inletOutlet;//was zeroGradient
        inletValue      $internalField;
    kaverneWall
        type            zeroGradient;
    outlet
        type            zeroGradient;
        //type            inletOutlet;//was zeroGradient
        //inletValue      uniform 293.15;
pipeWall
        type            zeroGradient;
    AMI
        type            zeroGradient;
    slide_interface
        type            zeroGradient;
    ACMI1_couple
        type            cyclicACMI;
    ACMI1_blockage
        type            zeroGradient;//was zeroGradient latest inletOutlet
       // type            calculated;
       // value           uniform 0;
    ACMI2_couple
        type            cyclicACMI;
    ACMI2_blockage
        type            zeroGradient;
        //type            calculated;
        //value           uniform 0;
U:
internalField   uniform (0 0 0);
boundaryField
    atmosphere
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    kaverneWall
        type            fixedValue;
    outlet
        type            zeroGradient;
    pipeWall
        type            fixedValue;
    AMI
        type            fixedValue;
    slide_interface
        type            fixedValue;
        value           uniform 0;
    ACMI1_couple
        type            cyclicACMI;
    ACMI1_blockage
        type            zeroGradient;
        //type            fixedValue;//was calculated
        //value           uniform (0 0 0);
 ACMI2_couple
        type            cyclicACMI;
    ACMI2_blockage
Any suggestions where i went wrong with my boundary conditions or could the error be somewhere else?
I'm happy about any help!
Cheers,
Oli
silencebreak is offline   Reply With Quote
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 18:45
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
