How to use temperatureDependentAlphaContactAngle |
Kei
Rep Power: 9 ![]() |
It's my first post on this forum, hello foamers
![]() I’m trying to simulate slug flow in a capillary tube by using interFoam. I would like to use temperature dependent interfacial tension and contact angle. I have changed “interfaceProperties” and “twoPhaseProperties” for that. The temperature dependence of the surface tension was made, but the contact angle was not made. So, I’m using "temperatureDependentAlphaContactAngle" in OpenFOAMv-1706. I could calculate by setting 0/alpha.water as follows, Code:
wall { type temperatureDependentAlphaContactAngle; theta0 constant 60; limit gradient; value uniform 0; } ![]() Could anybody please help me. Thanks. Kei |
sandy
Rep Power: 10 ![]() |
have you solved your problem???
Kei
Hi, saddy.
Thank you for your reply. Yes, I have been solved problem. However, I changed "twoPhaseProperties", instead of use "temperatureDependentAlphaContactAngle" to solve problem. Kei |
sandy
which openfoam version did you compile it for?//
Kei
I compiled library in OpenFOAM-2.3.1.
not OpenFOAM-v1706. |
contact angle, how to, interfoam with temp |
