airfoil with simpleFoam, High Renolds number and small y plus |
September 10, 2017, 22:34 |
Shanqin Jin
Rep Power: 9 |
Hi FOAMers:
I am working on the 2D airfoil simulation based on simpleFoam, I encouter some difficulties during the numerical simulation. In my case, the Y plus is too small, the smallest Y plus value is 0.03. Do you think that is too small and the openFoam can not solve this problem? Now the program can not run to the end and get final results. The Re=6000000. The Link is my case setting. https://www.dropbox.com/s/hbyhbccu99...0-100.zip?dl=0 The boundary information: https://www.dropbox.com/s/5r3upb6i0b...l%202.pdf?dl=0 |
airfoil, simplefoam, small y plus |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 19:32 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
VAWT using AMI very high courant number or very small time step | biau | OpenFOAM Running, Solving & CFD | 2 | April 2, 2013 10:13 |
Airfoil grid for turbulent flows: high aspect ratios | Marconi | Main CFD Forum | 1 | September 29, 2012 14:01 |
Difficulties in solving a high Reynolds number Flow? | wowakai | Main CFD Forum | 10 | December 29, 1998 14:46 |
