Dambreak case can't be simulated by the simple coupled level set and vof (sclsvof) |
September 8, 2017, 04:41 |
Rep Power: 9 |
Hi, every FOAMer!
At present, I am doing some interface tracking simulation such as dambreak flow. I have found a coupled method on the internet. This method coupled level set with VOF. And the relative codes(sclsVOFFoam) is compiled in OpenFOAM-3.0.1. I have done a case about bubble rising. The result of the simulation is fine. But when I try to do some dam break flow simulation using the sclsVOFFoam solver, this process always be failed. Please help me! The sclsVOFFoam code is in github( https://github.com/saatt/01-250SG ) The dambreak case is in github ( https://github.com/saatt/sclsVOFFoam ) |
January 21, 2018, 18:40 |
Yuanwei Cao
Rep Power: 9 |
Yes. I also find this problem. And it can not run in parallel. Do you find some solution? Is there any problem with this silver?
sclsvof dambreak flow |
CLSVOF + Eurelian model OR Multi-Fluid VOF Model + LEVEL SET | camilo_costa | Fluent Multiphase | 0 | April 29, 2014 12:59 |
the initialization of the coupled level set method and vof model in FLUENT 13.0 | dutliang | FLUENT | 3 | December 13, 2011 22:28 |
VOF vs Level Set Method for electrohydrodynamic waves | Rowland | Main CFD Forum | 0 | July 31, 2010 23:09 |
Level set vs VOF | steve | Main CFD Forum | 11 | September 16, 2008 01:22 |
Speed of VOF v.s. Level Set Method | Zi-Wei Chiou | Main CFD Forum | 8 | October 5, 2001 05:17 |
