compressibleInterDyMFoam and the troubles of the right thermophysical Parameters
Old   September 6, 2017, 11:27
Thumbs up compressibleInterDyMFoam and the troubles of the right thermophysical Parameters
Oliver K
silencebreak is on a distinguished road
Hey there,
I'm solving right now my first compressible Case and got a little bit of a hard time with the right thermophysical parameters. Actually I've run the case with interDyMFoam without any errors, so I don't think that the error could be provoked of the normal boundary conditions.
That's how the error message looks like:
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
AMI: Creating addressing and weights between 123 source faces and 2304 target faces
AMI: Patch source sum(weights) min/max/average = 0, 0.0644961, 0.00100825
AMI: Patch target sum(weights) min/max/average = 0, 1, 0.00392754
Selecting solid-body motion function tabulated6DoFMotion
Applying solid body motion to cellZone movingZone
Reading g
PIMPLE: max iterations = 100
    field p_rgh	: relTol 0, tolerance 5e-05
    field U	: relTol 0, tolerance 0.0001
Reading field p_rgh
Reading field U
Constructing twoPhaseMixtureThermo
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectFluid;
    specie          specie;
    energy          sensibleInternalEnergy;
#0  Foam::error::printStack(Foam::Ostream&) in "/projects2/OF_bin/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/projects2/OF_bin/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  ? in "/lib64/libc.so.6"
#3  Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectFluid<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::he(Foam::Field<double> const&, Foam::Field<double> const&, int) const in "/projects2/OF_bin/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#4  Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectFluid<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::init() in "/projects2/OF_bin/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"#5  Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectFluid<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) in "/projects2/OF_bin/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#6  Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectFluid<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heRhoThermo(Foam::fvMesh const&, Foam::word const&) in "/projects2/OF_bin/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#7  Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectFluid<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/projects2/OF_bin/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#8  Foam::autoPtr<Foam::rhoThermo> [...]
Floating point exception (core dumped)
I used the parameters of the given tutorial case which is running without any errors so the Problem should be in the file "thermophysicalProperties.water" which looks like:
thermoType
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
mixture
        nMoles      1;
        molWeight   18.0;
    equationOfState
        R           3000;
        rho0        1027;
    thermodynamics
        Cp          4195;
        Hf          0;
    transport
        mu          3.645e-4;
        Pr          2.289;
And for completion the thermophysicalProperties.air:
thermoType
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;//was sensibleInternalEnergy latest sensibleEnthalpy
mixture
    specie
        nMoles      1;
        molWeight   28.96;
    thermodynamics
        Cp          1004.5;//was 1007
        Hf          2.544e+06;//was 0
transport
        mu          1.8e-05;//was 1.84e-05
        Pr          0.7;
Did anyone have had some similar issues and got an answer?
//Edit: So for I got the first part to run. The issue results of incorrect T file for my ACMI BC. Actually the first part is loading but the error still exists for the air Part. Any ideas which BC is incorrect?
internalField   uniform 293.15;
boundaryField
    atmosphere
        type            calculated;
        value           $internalField;
    kaverneWall
        type            zeroGradient;
    outlet
        type            inletOutlet;//was zeroGradient
        inletValue      uniform 293.15;
    pipeWall
        type            zeroGradient;
    AMI
        type            zeroGradient;
    slide_interface
        type            zeroGradient;
    ACMI1_couple
        type            cyclicACMI;
    ACMI1_blockage
        type            zeroGradient;
       // type            calculated;
       // value           uniform 0;
    ACMI2_couple
        type            cyclicACMI;
    ACMI2_blockage
        type            zeroGradient;
        //type            calculated;
        //value           uniform 0;
A quick overview of my case:
I want to simulate a the outflow of a tank through a pipe which is closed after some time with a valve and want to calculate the water hammer effect. The patch atmosphere is the upper part of the tank and the rest explains itself i hope.
Cheers,
Oli
silencebreak is offline   Reply With Quote
Old   September 8, 2017, 09:19
Oliver K
Problem is solved. For everyone other expecting similar errors: You've got to check your T and especially for the ACMI-Patches you need to specify the value as internalFields.
Old   August 26, 2020, 05:01
Prasad ADHAV
Alpha001 is on a distinguished road
I have the same issue.
I am trying to simulate a water jet through nozzle.
But I am unsure of the boundary conditions, since no tutorial really covers a good case.
I have the following 0/T:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    wall
        type            zeroGradient;
    inlet
        type            zeroGradient;
    inlet2
        type            zeroGradient;
    inlet3
        type            zeroGradient;
    outlet
        type            zeroGradient;
I get the following error:
Create time
Selecting dynamicFvMesh staticFvMesh
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
    type            heRhoThermo;
    transport       const;
    thermo          eConst;
    specie          specie;
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:?
#4  Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#5  Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&) at ??:?
#6  Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#7  Foam::twoPhaseMixtureThermo::twoPhaseMixtureThermo(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#8  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/compressibleInterFoam"
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/compressibleInterFoam"
Any suggestions? I don't have ACMI BC.
Thank you for the help.
Alpha001 is offline   Reply With Quote
Old   November 19, 2020, 11:26
Default May just set everything to 300 Kelvin
Goeran Gabriel
goeran is on a distinguished road
| \\ / O peration | Version: v2006 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
location "0";
object T;
boundaryField
piston
type fixedValue;
value uniform 300;
fixedWall
type fixedValue;
value uniform 300;
walls
type fixedValue;
value uniform 300;
inlet
type fixedValue;
value uniform 300;
outlet
type inletOutlet;
inletValue uniform 300;
value uniform 300;
goeran is offline   Reply With Quote
Old   January 27, 2021, 02:44
Hector
hectorgabriel85 is on a distinguished road
Do you mean specifying value just for ACMI1_couple and ACMI2_couple? Or for ACMI1_blockage and ACMI2_blockage as well?
hectorgabriel85 is offline   Reply With Quote
Old   March 22, 2023, 09:51
Naira is on a distinguished road
FoamFile
    version     2.0;
    format      ascii;
    object      T;
boundaryField
    wall
        type            zeroGradient;
    inlet
        type            zeroGradient;
    inlet2
        type            zeroGradient;
    inlet3
        type            zeroGradient;
    outlet
        type            zeroGradient;
Create time
Reading field p_rgh
Reading field U
    type            heRhoThermo;
    transport       const;
    thermo          eConst;
    specie          specie;
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
Have you able to find the error, if so please help me in this regard. I am also getting the same error
Thank you
Naira is offline   Reply With Quote
