Nejc
Rep Power: 9 ![]() |
I've been struggling to make my pump case run for well over six months now and now I decided to split my problem(s) into smaller ones, starting with meshing. I made the simplest case I could think of: a sudden expansion joint, see attached pictures. To eliminate errors on the inlet edge I declared a 'slip' BC on a short section after inlet patch. I used k-omega SST turbulence model and wall functions. Boundary conditions are 1m/s inlet velocity and 0 outlet pressure, noSlip walls (except the mentioned patch). I tried with a few different meshes: - snappyHexMesh with 1, 0.5, 0.25 and 0.125mm 'smallest' cell without boundary layers - cfMesh with 1x 1mm, 3x 0.5mm and 5x 0.3mm boundary cells - cfMesh with 10x 8um boundary cells without wall functions I also tried the cfMesh cells without turbulence modelling. All except one laminar case converged. Here are a few numbers I think are important: Code:
mesh min size N*y+ Umax pmin snappy coarse 1mm 1.074 -0.217 snappy medium 0.5mm 1.073 -0.213 snappy fine 0.25mm 1.083 -0.221 snappy extrafine 0.125mm 1.088 -0.225 coarse layers 1x 1mm 110 1.243 -0.237 medium layers 3x 0.5mm 54 1.1 -0.247 fine layers 5x 0.3mm 33 1.103 -0.241 no wall functions 10x 9um 1 1.087 -0.301 y+ = 9um I now have no idea what the results mean. Are the results reasonable and which ones should be trusted most? Thanks! Last edited by kandelabr; September 4, 2017 at 09:34. Reason: added BC explanations |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
Need for Mesh Independence Study | nickninevah | Main CFD Forum | 6 | October 15, 2010 17:25 |
